Suspend Inactive Ports
678
Here are two EEM Tcl policies that work in concert to track ports that are operationally down for a given period of time.  If they are down long enough, then the ports are administratively shutdown (or placed in a quarantine VLAN if said VLAN is defined) to prevent unknown or untracked use of them.  Each policy uses some EEM environment variables.  For the timer policy:
# This policy runs at a configured time, then checks to see if inactive ports
# have been inactive for a configured amount of time.  If so, then the ports
# will be shutdown.
# This policy uses the following environment variables:
# suspend_ports_days        : Number of days before a port is suspended.
# suspend_ports_config      : Path to configuration file.
# suspend_quarantine_vlan   : (optional) VLAN number into which ports will be moved
#                             instead of being shutdown.  If not defined, ports will be
#                             shutdown.
And for the syslog policy:
# This policy listens for link up syslog messages, and removes the port from
# the list of down ports.
Beginner
Five Year Later, I have discovered the "ancient script" ....  Great work thanks
Content for Community-Ad
