This script was created for use on a uBR10012 to check if a crashinfo file is less than 24hrs old.
It can be modified for other platforms (it likely wouldn't need much manipulation in that case), and the first line...
::cisco::eem::event_register_none default 600 maxrun 600 sync yes
...can be changed so that the policy is a cron instead of manually triggered.
After triggering the script, the output would look like this:
091187: Feb 22 13:14:37.090: %HA_EM-6-LOG: tmpsys:/eem_policy/Crashinfo_Finder_v1.tcl: [EEM Event ID 21] started.
091188: Feb 22 13:14:41.322: %HA_EM-6-LOG: tmpsys:/eem_policy/Crashinfo_Finder_v1.tcl: disk0:crashinfo_20120222-051229-EDT is 0 days, 9 hours, 2 minutes, 12 seconds old.
091189: Feb 22 13:14:41.506: %HA_EM-6-LOG: tmpsys:/eem_policy/Crashinfo_Finder_v1.tcl: There are 65 crashinfo files across all filesystems.
091190: Feb 22 13:14:41.510: %HA_EM-6-LOG: tmpsys:/eem_policy/Crashinfo_Finder_v1.tcl: [EEM Event ID 21] finished.
The objective here is to run the script daily and send a trap if a new crashinfo file is detected.
124570-Crashinfo_Finder_v1.tcl.zip
