TCC_2
Level 10
Level 10
Core issue
Cisco Network Assistant (CNA) only supports these features on the Catalyst 4500 Series Switches:
  • Administration menu IP Address, Simple Network Management Protocol (SNMP),  System Time, HTTP Port, Users and Passwords, Console Baud Rate, MAC Addresses, Address Resolution Protocol (ARP), Save Configuration, Back Up/Restore Configuration, Software Upgrade, System Reload, and System Message Notification
  • Cluster menu Create Cluster, Delete Cluster, Add To Cluster, Remove From Cluster, and Hop Count
  • Port menu Smartports Port Setup, Port Settings, and Port Security
  • Device menu Hostname and Security Wizard
  • VLAN menu VLAN and Voice VLAN
  • Reports menu Inventory, Bandwidth Graphs, Link Graphs, and System Messages
  • View menu Front Panel, Topology, Topology Options, Automatic Topology Layout, and Save Topology Layout
Resolution
These limitations apply to the Cisco Catalyst 4500 Series Switches:
  • By default, clustering is disabled on Cisco Catalyst 4500 Series Switches.
  • An IP address must be assigned to the Cisco Catalyst 4500 Series Switch if it is a cluster command switch candidate. If the switch is a cluster member candidate, an IP address is not always necessary.
  • By default, the HTTP server is disabled on the Cisco Catalyst 4500 Series Switch. In order to connect the switch to CNA, enable the HTTP server on all cluster members.
  • The HTTP port number on Network Assistant and the Cisco Catalyst 4500 Series Switch must match.
  • A Cisco Catalyst 4500 Series Switch can be a cluster member only if another Catalyst 4500 is the command device.
  • By default, the Cisco Catalyst 4500 Series Switch is configured with five vty lines. If the switch   such as a cluster command device with multiple cluster members   is connected to the CNA, at least eight + x vty lines must be configured, where x is the number of vty lines used by other applications.  A maximum of 16 vty lines can be configured.
  • Create a Switch Virtual Interface (SVI) for intracluster communication. The SVI must be in the no shut state.
Refer to the Cluster Limitations and Restrictions section of Release Notes for Cisco Network Assistant 2.1 and Later for more details.
