TCC_2
Level 10
Level 10
Core issue
This issue occurs when the software image version currently running on the Supervisor Engine does not support the hardware that is inserted in the slot specified by the error message.
For example, if a module not supported by the current software was inserted into slot 3, a message similar to this is displayed:
   %SYS-5-MOD_INSERT:Module 3 has been inserted
   Invalid feature index set for module 3
Resolution
To resolve this issue, perform these steps:
  1. Identify the module and refer to the Catalyst 6500 Series Release Notes for the minimum and recommended software versions for the module.
  2. Verify that the version selected supports all modules in the switch and upgrade to the supported version.
    The Software Advisor may also be used to determine a compatible version.
For instructions on upgrading the supervisor software, refer to Upgrading Software Images on Catalyst 6000/6500 Series Switches.
