teegeorg
In the case of route distribution between BGP and LISP.
Description of the issue
  • The external host or server is unreachable from the Fabric host
  • The DHCP IP assignment fails
Pre SD-Access:
=== Core ===
router ospf 10
router-id 71.0.0.1
network 50.0.0.0 0.255.255.255 area 0
router bgp 65001
bgp router-id interface Loopback0
address-family ipv4 vrf Engineering
neighbor 200.0.0.2 remote-as 65002
With SD-Access:
##### FB1  ########
interface Loopback0
 description Fabric Node Router ID
 ip address 71.0.0.1 255.255.255.255
ip router isis
vrf definition Engineering
 rd 1:4099
 address-family ipv4
  route-target export 1:4099
  route-target import 1:4099
 exit-address-family
 address-family ipv6
 exit-address-family
interface Loopback1021 ----- ( Anycast gateway IP configured for DHCP OFFER punt)
 vrf forwarding Engineering
 ip address 100.1.1.1 255.255.255.255
router lisp
 locator-set rloc_set1
  IPv4-interface Loopback0 priority 10 weight 10
  auto-discover-rlocs
  exit-locator-set
 service ipv4
  encapsulation vxlan
  map-cache-limit 5119
  database-mapping limit dynamic 3000
  itr map-resolver 71.0.0.1
  etr map-server 71.0.0.1 key key1
  etr map-server 71.0.0.1 proxy-reply
  etr
  sgt
  proxy-etr
  proxy-itr 71.0.0.1
  map-server
  map-resolver
  exit-service-ipv4
instance-id 4097
  remote-rloc-probe on-route-change
  service ipv4
   eid-table default
   route-export site-registrations
   distance site-registrations 250
   map-cache site-registration
   exit-service-ipv4
  exit-instance-id
 instance-id 4098
  service ipv4
   eid-table vrf DEFAULT_VN
   exit-service-ipv4
exit-instance-id
 instance-id 4099
  service ipv4
   eid-table vrf Engineering
route-import database bgp 65001 route-map database locator-set rloc_set1 ( — Replacement of redistribute bgp under router ospf)
   exit-service-ipv4
  exit-instance-id
 site site_uci
  authentication-key key1
  eid-record instance-id 4097 0.0.0.0/0 accept-more-specifics
  eid-record instance-id 4098 0.0.0.0/0 accept-more-specifics
  eid-record instance-id 4099 0.0.0.0/0 accept-more-specifics
  exit-site
 ipv4 locator reachability exclude-default
 ipv4 source-locator Loopback0
 exit-router-lisp
router bgp 65001
 bgp log-neighbor-changes
 bgp graceful-restart
address-family ipv4 vrf vn1
  network 173.168.127.1 mask 255.255.255.255
  aggregate-address 173.168.227.0 255.255.255.0 summary-only
  aggregate-address 173.168.127.0 255.255.255.0 summary-only
  neighbor 200.0.0.2 activate
 exit-address-family
ip routing
route-map database permit 10
 match ip address prefix-list external_prefix
ip prefix-list external_prefix seq 5 permit 200.0.0.0/8
Solution
Ensure that the external prefixes learned from BGP are redistributed to LISP and registered to Control Plane and fabric LISP prefixes redistributed to BGP.
Pre-SDA Troubleshooting
show ip ospf neighbor
show ip bgp summary
show ip route ospf
show ip route bgp
Post-SDA Troubleshooting
Verify Export the MS/MR registrations into RIB
show lisp site
LISP Site Registration Information
* = Some locators are down or unreachable
# = Some registrations are sourced by reliable transport
Site Name      Last           Up     Who Last                   Inst     EID Prefix
                      Register             Registered                  ID
site_uci        2d14h     yes#       70.0.0.1                  4099       100.1.1.100/32
show ip route vrf Engineering
Routing Table: abcd
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B – BGP
            D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
            N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
            E1 - OSPF external type 1, E2 - OSPF external type 2
            i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
            ia - IS-IS inter area, * - candidate default, U - per-user static route
            o - ODR, P - periodic downloaded static route, H - NHRP, l – LISP
            a - application route
            + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
      200.0.0.0/32 is subnetted, 1 subnets
l       100.1.1.100 [240/1], 17:57:50, Null0
Verify Redistribute of LISP routes into BGP
show bgp vpnv4 unicast vrf Engineering
BGP table version is 4, local router ID is 71.0.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
              t secondary path,
Origin codes: i - IGP, e - EGP, ? – incomplete
RPKI validation codes: V valid, I invalid, N Not found
    Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:2 (default for vrf PACAF)
Export Map: vrf_to_global, Address-Family: IPv4 Unicast, Pfx Count/Limit: 1/1000
 *>   100.1.1.100/32      0.0.0.0                  0         32768 i
Verify Import of  BGP routes into LISP
show ip lisp route-import database instance-id 10
LISP IPv4 imported routes for EID-table vrf PACAF (IID 10)
Config: 1, Entries: 5 (limit 1000)
Prefix                    Uptime    Source               RLOC-set   Cache/DB   State
200.0.0.0/8              2d14h     bgp 65002            border     installed
show lisp site
                       2d14h     yes#    71.0.0.1                      4099     200.0.0.0/8
