teegeorg
Description of the issue and topology
  • External Host or Server reachability from Fabric host
  • DHCP IP assignment failure
Topology
Control Plane and Fabric Border are non-colocated
Configurations
Core:
router ospf 10
router-id 71.0.0.1
network 50.0.0.0 0.255.255.255 area 0
router bgp 65001
bgp router-id interface Loopback0
address-family ipv4 vrf Engineering
neighbor 200.0.0.2 remote-as 65002
With SDA:
##### FB1  ########
interface Loopback0
 description Fabric Node Router ID
 ip address 71.0.0.1 255.255.255.255
ip router isis
vrf definition vn1
 rd 1:4099
 address-family ipv4
  route-target export 1:4099
  route-target import 1:4099
 exit-address-family
 address-family ipv6
 exit-address-family
interface Loopback1021
 vrf forwarding vn1
 ip address 100.1.1.1 255.255.255.255
router lisp
 locator-set rloc_set1
  IPv4-interface Loopback0 priority 10 weight 10
  auto-discover-rlocs
  exit-locator-set
 service ipv4
  encapsulation vxlan
  map-cache-limit 5119
  database-mapping limit dynamic 3000
  itr map-resolver 71.0.0.10
  etr map-server 71.0.0.10 key key1
  etr map-server 71.0.0.10 proxy-reply
  etr
  sgt
  proxy-etr
  proxy-itr 71.0.0.1
  exit-service-ipv4
instance-id 4097
  remote-rloc-probe on-route-change
  service ipv4
   eid-table default
   distance site-registrations 250
   exit-service-ipv4
  exit-instance-id
 instance-id 4098
  service ipv4
   eid-table vrf DEFAULT_VN
   exit-service-ipv4
exit-instance-id
 instance-id 4099
  service ipv4
   eid-table vrf Engineering
 route-import map-cache bgp 65001 route-map PERMIT_EIDS
   route-import database bgp 65001 route-map db locator-set rloc_set1 < -----
   exit-service-ipv4
  exit-instance-id
 ipv4 locator reachability exclude-default
 ipv4 source-locator Loopback0
 exit-router-lisp
router bgp 65001
 bgp log-neighbor-changes
 bgp graceful-restart
address-family ipv4 vrf vn1
  network 173.168.127.1 mask 255.255.255.255
  aggregate-address 173.168.127.0 255.255.255.0 summary-only
  neighbor 175.5.5.2 remote-as 65002
  neighbor 175.5.5.2 activate
 exit-address-family
 address-family vpnv4
  neighbor 50.0.0.200 activate
  neighbor 50.0.0.200 send-community both
 exit-address-family
ip routing
route-map db deny 10
 match community 1
route-map db permit 20
route-map PERMIT_EIDS permit 10
 match community 1
route-map PERMIT_EIDS deny 20
Control Plane:
interface Loopback0
 ip address 71.0.0.10 255.255.255.255
ip router isis
vrf definition Engineering
 rd 1:4099
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
router lisp
  auto-discover-rlocs
  exit-locator-set
 service ipv4
  encapsulation vxlan
  map-server
  map-resolver
  exit-service-ipv4
instance-id 4097
  service ipv4
   eid-table default
   route-export site-registrations
   exit-service-ipv4
  exit-instance-id
 instance-id 4098
  service ipv4
   exit-service-ipv4
exit-instance-id
 instance-id 4099
  service ipv4
   exit-service-ipv4
  exit-instance-id
 site site_uci
  authentication-key key1
  eid-record instance-id 4097 0.0.0.0/0 accept-more-specifics
  eid-record instance-id 4098 0.0.0.0/0 accept-more-specifics
  eid-record instance-id 4099 0.0.0.0/0 accept-more-specifics
  exit-site
 exit-router-lisp
router bgp 65001
 neighbor 50.0.0.100 remote-as 65001
  neighbor 50.0.0.100 activate
  neighbor 50.0.0.100 send-community both
  neighbor 50.0.0.100 route-map tag out
 exit-address-family
  aggregate-address 100.0.0.0 255.0.0.0 summary-only < send the aggregate route only >
  redistribute lisp metric 10 < redistribute lisp to BGP >
 exit-address-family
route-map tag permit 10
 set community 655370
Possible Causes
  • External prefixes not advertised to Fabric Border
  • External prefixes not registered to Control Plane
  • Fabric prefixes registered to Control Plane not getting advertised to Border through MPLS VPN
  • Incorrect route-maps resulting in non advertisement of Fabric routes to external BGP domain
Solution
Ensuring external prefixes learnt from BGP registered to MS/MRR and Fabric LISP prefixes redistributed
MPLS VPNv4 connection should carry fabric routes with the correct community values
Pre-SD-Access Troubleshooting
show ip ospf neighbor
show ip bgp summary
show ip route ospf
show ip route bgp
Post-SD-Access Troubleshooting
Verify export of the MS/MR registrations into RIB on Control Plane
show lisp site
LISP Site Registration Information
* = Some locators are down or unreachable
# = Some registrations are sourced by reliable transport
Site Name      Last           Up     Who Last                   Inst     EID Prefix
                      Register             Registered                  ID
site_uci        2d14h     yes#       70.0.0.1                  4099       100.1.1.100/32
show ip route vrf Engineering
Routing Table: abcd
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B – BGP
            D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
            N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
            E1 - OSPF external type 1, E2 - OSPF external type 2
            i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
            ia - IS-IS inter area, * - candidate default, U - per-user static route
            o - ODR, P - periodic downloaded static route, H - NHRP, l – LISP
            a - application route
            + - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
      200.0.0.0/32 is subnetted, 1 subnets
l       100.1.1.100 [240/1], 17:57:50, Null0
Verify redistribution of LISP routes into BGP on Control Plane
show bgp vpnv4 unicast vrf Engineering
BGP table version is 4, local router ID is 71.0.0.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
              t secondary path,
Origin codes: i - IGP, e - EGP, ? – incomplete
RPKI validation codes: V valid, I invalid, N Not found
    Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:2 (default for vrf PACAF)
Export Map: vrf_to_global, Address-Family: IPv4 Unicast, Pfx Count/Limit: 1/1000
 *>   100.1.1.100/32      0.0.0.0                  0         32768 i
Verify the import of BGP routes into LISP
## verify the LISP MS/MR routes learnt via VPNv4 on Fabric Border
SG1#show ip route vrf vn1
Routing Table: vn1
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
       n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
       H - NHRP, G - NHRP registered, g - NHRP registration summary
       o - ODR, P - periodic downloaded static route, l - LISP
      100.0.0.0/8 is subnetted, 1 subnets
B        100.0.0.0 [200/0] via 71.0.0.10, 00:16:39
### Verify the prefix is pointing to LISP interface in CEF and not BGP
SG1#show ip cef vrf vn1 100.0.0.0 int
100.0.0.0/8, epoch 1, flags [sc, lisp elig], refcnt 6, per-destination sharing
  sources: LISP, IPL
  feature space:
    IPRM: 0x00010000
    Broker: linked, distributed at 1st priority
  subblocks:
    LISP remote EID: 2 packets 1152 bytes fwd action signal, cfg as EID space
    SC owned,sourced: LISP generalised SMR - [enabled, inheriting, 0x7FD0F4E27E00 locks: 1]
    LISP source path list
      path list 7FD0F2AD9D78, 8 locks, per-destination, flags 0x49 [shble, rif, hwcn]
        ifnums:
          LISP0.4099(116)
        1 path
          path 7FD0F17E9D70, share 1/1, type attached prefix, for IPv4
            attached to LISP0.4099, glean for LISP0.4099
        1 output chain
          chain[0]: glean for LISP0.4099
      Dependent covered prefix type LISP, cover 0.0.0.0/0
    2 IPL sources [no flags]
  ifnums:
    LISP0.4099(116)
  path list 7FD0F2AD9D78, 7 locks, per-destination, flags 0x49 [shble, rif, hwcn]
  output chain:
    PushCounter(LISP:100.0.0.0/8) 7FD0E946CD80
    glean for LISP0.4099 <---- this is to trigger a map-request for the traffic destined to this prefix (Note not pointing to BGP adjacency)
## You can verify the community value tagged to the route
SG1#show ip bgp vpnv4 vrf vn1 100.0.0.0/8
BGP routing table entry for 1:4099:100.0.0.0/8, version 12
Paths: (1 available, best #1, table vn1)
  Advertised to update-groups:
  Refresh Epoch 1
  Local, (aggregated by 65001 71.0.0.10)
    71.0.0.10 (metric 20) (via default) from 71.0.0.10 (71.0.0.10)
      Origin IGP, metric 0, localpref 100, valid, internal, atomic-aggregate, best
      Community: 655370 < ----- Community value tagged at Control Plane
      Extended Community: RT:1:4099
      mpls labels in/out nolabel/34
      rx pathid: 0, tx pathid: 0x0
      Updated on Nov 26 2018 16:43:56 UTC
