06-27-2012 04:27 PM - edited 11-18-2020 02:59 AM
*May 30 00:16:21.886: %CAPWAP-3-ERRORLOG: Go join a capwap controller examining image...! extracting info (332 bytes) Image info: Version Suffix: k9w8-.ap_jmr3_esc.201205290806 Image Name: ap3g1-k9w8-mx.ap_jmr3_esc.201205290806 Version Directory: ap3g1-k9w8-mx.ap_jmr3_esc.201205290806 Ios Image Size: 1004032 Total Image Size: 6820352 Image Feature: WIRELESS LAN|LWAPP Image Family: AP3G1 Wireless Switch Management Version: 7.0.230.11 Extracting files... ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ (directory) 0 (bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/D5.bin (45248 bytes)!!! ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/ (directory) 0 (bytes) ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/ (directory) 0 (bytes) ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/ (directory) 0 (bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/forms.js (17486 bytes)! *May 28 20:20:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.2.52 peer_port: 5246 *May 28 20:20:26.578: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.2.52 peer_port: 5246 *May 28 20:20:26.578: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.2.52 *May 28 20:20:26.581: %CAPWAP-3-ER! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/sitewide.js (16548 bytes)RORLOG: CAPWAP parameters update to forwarding plane failedperform archive download capwap:/ap3g1 tar file *May 28 20:20:26.585: %CAPWAP-6-AP_IMG_DWNLD: Required image not found on AP. Downloading image from Controller. *May 28 20:20:26.597: Loading file /ap3g1... ! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/officeExtendap.css (41795 bytes)!!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/appsui.js (557 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/config.js (24633 bytes)!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/ap_home.shtml.gz (1300 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/back.shtml (506 bytes) ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/images/ (directory) 0 (bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/images/cisco-logo-2007.gif (1648 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/images/background_web41.jpg (732 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/images/login_homeap.gif (19671 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/1/images/info.gif (399 bytes) ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/ (directory) 0 (bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/officeExtendapBanner.htm (7108 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/officeExtendapHelp.htm (5007 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/officeExtendapEvent.shtml.gz (983 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/officeExtendapConfig.shtml.gz (2861 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/officeExtendapMain.shtml.gz (3361 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/html/level/15/officeExtendapSummary.htm (712 bytes) extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806 (113051 bytes)!!!!!!!!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/u-boot.bin (393216 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/G5.bin (34340 bytes)!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/D2.bin (11716 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/Z2.bin (10504 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-xx.ap_jmr3_esc.201205290806 (4727868 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! *May 28 20:22:26.591: %CAPWAP-3-ERRORLOG: Invalid event 48 & state 10 combination. *May 28 20:22:26.591: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer message. Event 48, state 10 *May 28 20:22:26.591: %CAPWAP-3-ERRORLOG: Failed to handle timer message. *May 28 20:22:26.594: %CAPWAP-3-ERRORLOG: Failed to process timer message.!!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/G2.bin (6868 bytes)! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-boot-m_upg (393216 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/8003.img (882076 bytes)!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/Z5.bin (29492 bytes)!! extracting ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/info (332 bytes)! extracting info.ver (332 bytes) Deleting current version: flash:/ap3g1-k9w8-mx.ap_k_esc.201204181323...done. New software image installed in flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806 Configuring system to use new image...done. archive download: takes 154 seconds ReIniting the reap config file flash:/lwapp_reap.cfg Writing out the event log to nvram... *May 28 20:23:02.355: image upgrade successfully, system is now reloading *May 28 20:23:02.437: %SYS-5-RELOAD: Reload requested by capwap image download proc. Reload Reason: NEW IMAGE DOWNLOAD. *May 28 20:23:02.440: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN r WRDTR,CLKTR: 0x84000800 0x00000000 r RQDC ,RFDC : 0x80000033 0x00000256 using eeprom values WRDTR,CLKTR: 0x84000800 0x00000000 RQDC ,RFDC : 0x80000033 0x00000256 ddr init done Running Normal Memtest... Passed. IOS Bootloader - Starting system. FLASH CHIP: Numonyx P33 Checking for Over Erased blocks ...................................................................................................................................................................................................................................................... Xmodem file system is available. DDR values used from system serial eeprom. WRDTR,CLKTR: 0x84000800, 0x00000000 RQDC, RFDC : 0x80000033, 0x00000256 PCIE0: link is up. PCIE0: VC0 is active PCIE1: link is up. PCIE1: VC0 is active 64bit PCIE devices PCIEx: initialization done flashfs[0]: 67 files, 14 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 31739904 flashfs[0]: Bytes used: 15255552 flashfs[0]: Bytes available: 16484352 flashfs[0]: flashfs fsck took 12 seconds. Reading cookie from system serial eeprom...Done Base Ethernet MAC address: c8:9c:1d:f4:66:85 Ethernet speed is 1000 Mb - FULL duplex Loading "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806"...################ File "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806" uncompressed and installed, entry point: 0x4000 executing... enet halted IOS Secondary Bootloader - Starting system. FLASH CHIP: Numonyx P33 Checking for Over Erased blocks ...................................................................................................................................................................................................................................................... Xmodem file system is available. DDR values used from system serial eeprom. WRDTR,CLKTR: 0x84000800, 0x00000000 RQDC, RFDC : 0x80000033, 0x00000256 PCIE0: link is up. PCIE0: VC0 is active PCIE1: link is up. PCIE1: VC0 is active 64bit PCIE devices PCIEx: initialization done flashfs[0]: 67 files, 14 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 31739904 flashfs[0]: Bytes used: 15255552 flashfs[0]: Bytes available: 16484352 flashfs[0]: flashfs fsck took 10 seconds. Reading cookie from system serial eeprom...Done Base Ethernet MAC address: c8:9c:1d:f4:66:85 Creating Test Kernel diagnostic commands Radio 0 : Vendor 0x11AB, Device 0x8324 Radio 1 : Vendor 0x11AB, Device 0x8350 Radio 2 : Vendor 0x4816, Device 0xD4FD Radio 3 : Vendor 0x2F83, Device 0x0 ******** AUTOMATIC DDR CALIBRATION UPGRADE LOGIC ********* === 1. Is original FCS bootloader in BS:? If not, skip upgrade === ---> original FCS bootloader was detected at bs: === 2. Has upgrade logic already ran once? (flag!=0xffffffff) ---> upgrade logic has not run yet === 3. Read 0x1e0/0x210 EEPROM values === === 4. Are 0x1e0 EEPROM signatures found? ---> eeprom signatures were not found === 5. Writing MICRON static values to eeprom at addr 0x210 ---> write to eeprom complete === 6. Copy u-boot to BB: ................................................................................................ File "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/u-boot.bin" successfully copied to "bb:" === 7. Copy new bootloader to BS: ................................................................................................ File "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-boot-m_upg" successfully copied to "bs:" === 8. Write 0x0 to EEPROM upgrade flag to trigger u-boot ---> write to eeprom complete === 9. Reset system. Run u-boot DDR calibration r WRDTR,CLKTR: 0x84000800 0x00000000 r RQDC ,RFDC : 0x80000033 0x00000256 using eeprom values WRDTR,CLKTR: 0x84000800 0x00000000 RQDC ,RFDC : 0x80000033 0x00000256 using MCNG ddr static values from serial eeprom ddr init done U-Boot 2011.03-cisco-P3-AP1140-rc1 Merged - CLKTR/WRDTR Seeds at 0x290/0x294 0X01E0 EEPROM, Verify EEPROM Checksum For Seed Values, Direct Write to CLKTR/WRDTR (Mar 21 2012 - 14:43:21) CPU: AMCC PowerPC 460 UNKNOWN (PVR=130218a8) at 666.666 MHz (PLB=166, OPB=83, EBC=41 MHz) Bootstrap Option H - Boot ROM Location I2C (Addr 0x52) 32 kB I-Cache 32 kB D-Cache Board: Canyonlands - AMCC PPC460EX Evaluation Board, 1*PCIe/1*SATA, Rev. 1F I2C: ready DTT: 1 FAILED INIT DRAM: --------Retrieving DDR values from EEPROM-------- -- DDR Configuration During Calibration: -- SDRAM_RTR = 0x05100000 -- SDRAM_MCOPT1 = 0x04d22000 -- SDRAM_MCOPT2 = 0x08000000 -- SDRAM_MODT0 = 0x01000000 -- SDRAM_MODT1 = 0x00000000 -- SDRAM_MODT2 = 0x00000000 -- SDRAM_MODT3 = 0x00000000 -- SDRAM_CODT = 0x00800021 -- SDRAM_MB0CF = 0x00005201 -- SDRAM_MB1CF = 0x00000000 -- SDRAM_MB2CF = 0x00000000 -- SDRAM_MB3CF = 0x00000000 -- SDRAM_INITPLR0 = 0xa1b80000 -- SDRAM_INITPLR1 = 0x81900400 -- SDRAM_INITPLR2 = 0x81020000 -- SDRAM_INITPLR3 = 0x81030000 -- SDRAM_INITPLR4 = 0x81010004 -- SDRAM_INITPLR5 = 0xe4800532 -- SDRAM_INITPLR6 = 0x81900400 -- SDRAM_INITPLR7 = 0x89080000 -- SDRAM_INITPLR8 = 0x89080000 -- SDRAM_INITPLR9 = 0x89080000 -- SDRAM_INITPLR10 = 0x89080000 -- SDRAM_INITPLR11 = 0x81000432 -- SDRAM_INITPLR12 = 0x81010384 -- SDRAM_INITPLR13 = 0x81010004 -- SDRAM_INITPLR14 = 0x00000000 -- SDRAM_INITPLR15 = 0x00000000 -- SDRAM_SDTR1 = 0x00201000 -- SDRAM_SDTR2 = 0x32204232 -- SDRAM_SDTR3 = 0x070a0d12 -- SDRAM_MMODE = 0x00000432 -- SDRAM_MEMODE = 0x00000004 Autocalibration using window set 0 Auto calibration - Key: WRDTR = SDRAM0_WRDTR CLKTR = SDRAM0_CLKTR RFFDs = Start of window for SDRAM0_RFDC[RFFD] RFFDe = End of window for SDRAM0_RFDC[RFFD] RFFDsz = Size of window for SDRAM0_RFDC[RFFD] RQFDs = Start of window for SDRAM0_RQDC[RQFD] RQFDe = End of window for SDRAM0_RQDC[RQFD] RQFDsz = Size of window for SDRAM0_RQDC[RQFD] RDSS = Read Sample Cycle (SDRAM0_RDCC[RDSS]) WDRTR CLKTR RFFDs RFFDe RFFDsz RQFDs RQFDe RQFDsz RDSS --------Retrieving Cisco WRDTR/CLKTR Seed Values from EEPROM-------- --------CLKTR in EEPROM at 0x00000290-------- --------Using Cisco CLKTR from EEPROM 0x40000000-------- --------WRDTR in EEPROM at 0x00000294-------- --------Using Cisco WRDTR from EEPROM 0x8200083F-------- \|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-0x8200083f 0x40000000 0x019f 0x028b 236 0x0000 0x0063 100 T2 *** -- Final Calibration Results -- ** WRDTR = 0x8200083f ** CLKTR = 0x40000000 ** RFDC[RFFD] = 0x0215 ** RQDC[RQFD] = 0x0031 ** RFFD window: 0x019f <-> 0x028b (236) ** RQFD window: 0x0000 <-> 0x0063 (100) ** RDCC = 0x40000001 *** ------------------------------- --------Cisco Memtest Passed-------- eeprom vals: 0x01E0--face9876 40000000 8200083f 80000031 00000215 eebb2299 5675b0f4 ################################################## #### TRIGGER RESET - BEFORE FUNCTION do_reset #### ##################################################ÿ r WRDTR,CLKTR: 0x8200083f 0x40000000 r RQDC ,RFDC : 0x80000031 0x00000215 using eeprom values WRDTR,CLKTR: 0x8200083f 0x40000000 RQDC ,RFDC : 0x80000031 0x00000215 using MCNG ddr static values from serial eeprom ddr init done Running Normal Memtest... Passed. IOS Bootloader - Starting system. FLASH CHIP: Numonyx P33 Checking for Over Erased blocks ...................................................................................................................................................................................................................................................... Xmodem file system is available. DDR values used from system serial eeprom. WRDTR,CLKTR: 0x8200083f, 0x40000000 RQDC, RFDC : 0x80000031, 0x00000215 PCIE0: link is up. PCIE0: VC0 is active PCIE1: link is up. PCIE1: VC0 is active 64bit PCIE devices PCIEx: initialization done flashfs[0]: 67 files, 14 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 31739904 flashfs[0]: Bytes used: 15255552 flashfs[0]: Bytes available: 16484352 flashfs[0]: flashfs fsck took 10 seconds. Reading cookie from system serial eeprom...Done Base Ethernet MAC address: c8:9c:1d:f4:66:85 Ethernet speed is 1000 Mb - FULL duplex Loading "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806"...################ File "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806" uncompressed and installed, entry point: 0x4000 executing... enet halted IOS Secondary Bootloader - Starting system. FLASH CHIP: Numonyx P33 Checking for Over Erased blocks ...................................................................................................................................................................................................................................................... Xmodem file system is available. DDR values used from system serial eeprom. WRDTR,CLKTR: 0x8200083f, 0x40000000 RQDC, RFDC : 0x80000031, 0x00000215 PCIE0: link is up. PCIE0: VC0 is active PCIE1: link is up. PCIE1: VC0 is active 64bit PCIE devices PCIEx: initialization done flashfs[0]: 67 files, 14 directories flashfs[0]: 0 orphaned files, 0 orphaned directories flashfs[0]: Total bytes: 31739904 flashfs[0]: Bytes used: 15255552 flashfs[0]: Bytes available: 16484352 flashfs[0]: flashfs fsck took 10 seconds. Reading cookie from system serial eeprom...Done Base Ethernet MAC address: c8:9c:1d:f4:66:85 Creating Test Kernel diagnostic commands Radio 0 : Vendor 0x11AB, Device 0x8324 Radio 1 : Vendor 0x11AB, Device 0x8350 Radio 2 : Vendor 0xFFF9, Device 0xA277 Radio 3 : Vendor 0xFFF9, Device 0xA25B ******** AUTOMATIC DDR CALIBRATION UPGRADE LOGIC ********* === 1. Is original FCS bootloader in BS:? If not, skip upgrade === ---> original FCS bootloader not detected -- skip upgrade Boot CMD: 'boot flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-xx.ap_jmr3_esc.201205290806;flash:/ap3g1-k9w8-mx.v124_23c_ja.201109061133/ap3g1-k9w8-mx.v124_23c_ja.201109061133' Loading "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-xx.ap_jmr3_esc.201205290806"...########################################################################################################################################################################################################################################################################################################################################################################################################################################################################## File "flash:/ap3g1-k9w8-mx.ap_jmr3_esc.201205290806/ap3g1-k9w8-xx.ap_jmr3_esc.201205290806" uncompressed and installed, entry point: 0x4000 executing... Restricted Rights Legend Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013. cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706 Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Experimental Version 12.4(20120529:152242) [BLD-ap_jmr3_esc.201205290806 157] Copyright (c) 1986-2012 by Cisco Systems, Inc. Compiled Tue 29-May-12 09:02 by Proceeding with system init Proceeding to unmask interrupts Initializing flashfs... FLASH CHIP: Numonyx P33 Checking for Over Erased blocks ...................................................................................................................................................................................................................................................... flashfs[1]: 67 files, 14 directories flashfs[1]: 0 orphaned files, 0 orphaned directories flashfs[1]: Total bytes: 31481856 flashfs[1]: Bytes used: 15255552 flashfs[1]: Bytes available: 16226304 flashfs[1]: flashfs fsck took 7 seconds. flashfs[1]: Initialization complete. flashfs[2]: 0 files, 1 directories flashfs[2]: 0 orphaned files, 0 orphaned directories flashfs[2]: Total bytes: 11999232 flashfs[2]: Bytes used: 1024 flashfs[2]: Bytes available: 11998208 flashfs[2]: flashfs fsck took 1 seconds. flashfs[2]: Initialization complete....done Initializing flashfs. Ethernet speed is 1000 Mb - FULL duplex Radio0 present 8364B 8000 B8020000 0 B8030000 10 Radio1 present 8364B 8000 B0020000 0 B0030000 C This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco AIR-CAP3502I-A-K9 (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory. Processor board ID FTX1512E24N PowerPC460exr CPU at 666Mhz, revision number 0x18A8 Last reset from reload LWAPP image version 7.0.230.11 1 Gigabit Ethernet interface 2 802.11 Radio(s) 32K bytes of flash-simulated non-volatile configuration memory. Base ethernet MAC Address: C8:9C:1D:F4:66:85 Part Number : 73-12175-04 PCA Assembly Number : 800-32268-04 PCA Revision Number : A0 PCB Serial Number : FOC15074K7F Top Assembly Part Number : 800-32891-01 Top Assembly Serial Number : FTX1512E24N Top Revision Number : A0 Product/Model Number : AIR-CAP3502I-A-K9 % Please define a domain-name first. Press RETURN to get started! *Mar 1 00:00:09.622: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed *Mar 1 00:00:09.635: *** CRASH_LOG = YES *Mar 1 00:00:09.635: 64bit PCIE devicesSecurity Core found. Base Ethernet MAC address: C8:9C:1D:F4:66:85 *Mar 1 00:00:12.469: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up *Mar 1 00:00:13.234: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 *Mar 1 00:00:13.649: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up *Mar 1 00:00:15.920: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 *Mar 1 00:00:15.974: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 1024 messages) *Mar 1 00:00:15.989: status of voice_diag_test from WLC is false *Mar 1 00:00:18.116: %SYS-5-RESTART: System restarted -- Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Experimental Version 12.4(20120529:152242) [BLD-ap_jmr3_esc.201205290806 157] Copyright (c) 1986-2012 by Cisco Systems, Inc. Compiled Tue 29-May-12 09:02 by *Mar 1 00:00:18.116: %SNMP-5-COLDSTART: SNMP agent on host APc89c.1df4.6685 is undergoing a cold start *Mar 1 00:13:45.044: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY *Mar 1 00:13:45.128: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset *Mar 1 00:13:45.128: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset *Mar 1 00:13:45.292: %SSH-5-ENABLED: SSH 2.0 has been enabled *Mar 1 00:13:45.962: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up *Mar 1 00:13:46.129: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down *Mar 1 00:13:46.129: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down *Mar 1 00:14:00.300: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface GigabitEthernet0 obtained IP from DHCP... *Mar 1 00:14:00.319: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 172.16.35.12, mask 255.255.255.0, hostname APc89c.1df4.6685 *Mar 1 00:14:00.319: %LWAPP-3-LWAPP_INTERFACE_GOT_IP_ADDRESS: Interface GigabitEthernet0 obtained IP from DHCP... *Mar 1 00:14:03.918: status of voice_diag_test from WLC is false *Mar 1 00:14:03.990: Logging LWAPP message to 172.16.1.10. *Mar 1 00:14:04.572: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source *Mar 1 00:14:04.667: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up *Mar 1 00:14:04.764: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up *Mar 1 00:14:05.009: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up *Mar 1 00:14:05.009: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up *Mar 1 00:14:05.009: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.1.10 started - CLI initiated Translating "CISCO-CAPWAP-CONTROLLER.clients.escalation.cisco.com"...domain server (172.16.0.10) *May 28 20:26:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.2.52 peer_port: 5246 *May 28 20:26:22.000: %CAPWAP-5-CHANGED: CAPWAP changed state to *May 28 20:26:22.581: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 172.16.2.52 peer_port: 5246 *May 28 20:26:22.581: %CAPWAP-5-SENDJOIN: sending Join Request to 172.16.2.52 *May 28 20:26:22.581: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN *May 28 20:26:22.824: %CAPWAP-5-CHANGED: CAPWAP changed stat wmmAC status is FALSEe to CFG *May 28 20:26:23.148: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to down *May 28 20:26:23.296: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset *May 28 20:26:23.311: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up *May 28 20:26:23.896: %CAPWAP-5-CHANGED: CAPWAP changed state to DOWN *May 28 20:26:24.054: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down *May 28 20:26:24.186: %LWAPP-3-CLIENTEVENTLOG: OfficeExtend Localssid saved in AP flash *May 28 20:26:24.214: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down *May 28 20:26:24.214: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down *May 28 20:26:24.261: %LWAPP-3-CLIENTEVENTLOG: Received AP Syslog IP Address(255.255.255.255) configuration. *May 28 20:26:24.264: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.1.10 stopped - CLI initiated *May 28 20:26:24.592: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller ESC_5508-500_52
I saw a couple of 3500s do this today and one would receive POE but the ethernet link wouldn't come up and the other one worked fine on the same drop with the same patch cables. I've noticed that sometimes certain patch cables won't sit into Cisco APs well and they will receive POE but won't get a good ethernet connection. I'm not sure if all 3500s do this "automatic DDR calibration upgrade logic" or not or if these two phenomenom are even related.
