Javier Contreras
8.0.115.x Available - 8.0MR2 Beta
July 8th
Final code 8.0.120.0 now posted in CCO, thanks for your interest.
Issues fixed on this release
8.0.115.30
CSCuq906323702 crashed with a traceback
CSCuu81895New 1572 out of box AP in local mode not starting CAPWAP process
8.0.115.26
CSCuu370773600P limited channels/power similar to CSCus35411
CSCuu20683RAP might lose the Native VLAN configuration on downgrade from 8.1
CSCuu20256Traffic drop on WLCs with 7.6.130.206 and PMIPv6
CSCut05252OEAP: Auth rejected because of challenge failure ReasonCode: 15
CSCut47761PMIPv6 Client crash with .1x auth when user name have colon ':'
8.0.115.18
CSCun56310#LWAPP-3-VENDOR_PLD_VALIDATE_ERR: SPAM_VENDOR_SPECIFIC_PAYLOAD(185)
CSCus448311702 AP reports power error with 802.3af power source
CSCus252561130 Flexconnect APs sometimes lose bridge-group configuration
CSCuq97914PI 1.4 cannot finish auditing WLC
CSCus26067HA failing after upgrade to 8.0 due to gateway ARP source mac
CSCus72994WLC Crash on Task Name:DHCP Socket Task
CSCus94968osapiMalloc accepting negative size buffers
CSCut98741WLC Monitor page needs to support session timeout
CSCut14210Flexconnect arp-cache enabled - AP is not responding on behalf of client
CSCus30769BSSID containing itself and also adding itself to client exclusion list.
CSCuq86269DFS detection due to broadcom spurious emissions
8.0.115.11
CSCus48787AP:Radio d1 reset: FW: vec=36 pc=10FC4, irq/mac stat=20000/80
CSCur53041DTLS connection failure.
CSCus39358Apple and Android not connecting to WPA2-AES on OEAP600 8.0.110
CSCus44802WLAN NAS-id is not applied when AP Group NAS-id is changed
CSCus06920preauth bit set in RSN IE when wlan is wpa2AES
CSCut96026SGT remains for client when moving between WLANs with Fast SSID change
CSCuq48218WLC cannot process multiple sub-attributes in single RADIUS VSA
CSCur45862AP's cannot discover wlc through option 43 on build 8.0.100
CSCuq09859APs sending GARP and ARP requests aprox every 2 seconds.
CSCuq48800Low throughput due to UAPSD for Intel 7260 WiFi chipset
CSCuo09947RADIUS AVP #44 (Acct-Session-ID) to be sent in RADIUS authen messages
CSCur45453web Gui 8500 new mobility support and SPG configuration to be blocked
CSCur56576WLC doesn't support 802.11a for Qatar
CSCur92472PMIPv6: Roaming WLC1->WLC2 don't work, wrong handoff indicator
CSCus31292Oct 2014 OpenSSL Vulnerabilities
CSCus85767Flex local switch clients, local dhcp are trying to do central dhcp
CSCut45950MARCH 2015 OpenSSL Vulnerabilitiess
8.0.115.7
CSCus45806Enable CDP Spare pair TLV for 1570 and 1530 series access points
CSCur22714Ap3602 trying to contain its own RM3000AC module
CSCut261373702 - Voice Queue stuck, with no new clients able to associate.
CSCur37475wism2 system crash - at client stats AVL corruption
CSCus13594slow in getting the DHCP address in the AP2700
CSCur786971st Hop MAP CAPWAP Restart Due to race condition  when seeking RAP2
CSCur72287EAPOL Security error seen when 1st HOP MAP Roams  from RAP1 to RAP2
CSCus48452MAPs do not return to configured channel along with RAP 30 after DFS
CSCus49126AP3702 floods RTS frames @ 8000pps to departed client
CSCuq99230AP syslog fails due to default setting 'logging server-arp'
CSCus85337CAPWAP Restart &  Gteway not reachable when MAP roams From RAP1 to RAP2
CSCuq48043IPv6 forwarding halts; broadcast queue full
CSCur52246PMIPv6  GRE key databse gets full during scale testing
CSCur71427Flex: Client roaming fails "not processing DOT1X_4WAY_COMPLETED_AT_AP"
CSCur74954central auth + local switching : clients are in idle state always
CSCus80059WLC always send authen packet to aaa server even no any client in WLC
CSCut31679Kernel panic  -Unhandled kernel unaligned access
8.0.115.3
CSCuq60042Memory leak on WLC when using PMIPv6 clients  pem_api.c
CSCuq63642Internal webpage appears after successful redirect to external webauth
CSCur002888.0.100.0 client is shown with "ip address unknown" and "dhcp required"
CSCur302988500 new mobility support for guest anchor and block spg config
CSCur50819BEAST Vulnerability not properly resolved in Cisco WLCs
CSCur67701Image download errors for CAPWAP 7500/8500
CSCus39461Radius DNS adds both Network and Management Auth + Acct = Enabled
CSCus46861LIZRD attack : Denial of Service
CSCus640731700/2700 APs native vlan field missing in Flex tab
CSCut07617Signal 11 crash at PMIPV6_Thread_1
CSCut26403AP1242 does not forward SIP INVITE when SIP-CAC is enabled
8.0.115.2
CSCus876733700 AP 5ghz Radio Reset
CSCur888643600 APs with AC module shows 100% Rx utilization on slot-2.
CSCur23656Cisco IOS and IOSd in IOS-XE : evaluation of SSLv3 POODLE vulnerability
CSCuq19142LAP/WLC MIC lifetime expiration causes DTLS failure
CSCuq54548Anchor Memory Leak when Sleeping Client Feature is enabled
CSCuq74491WLC 8.0.100.0 crashes due to Task Name: apfRogueTask_0
CSCur20154HA SSO pair memory leak
CSCur96221Standby WLC crash at haSSOServiceTask6
CSCus21276Kernel Panic on wism2 for 8.0MR1 beta
CSCus38268Memory Leak on WiSM2 due to SNMPTask on 7.4.121.0
CSCus42727JANUARY 2015 OpenSSL Vulnerabilities
CSCus55004WLC2504 8.0MR1: Kernel Panic with pre-auth ACL and external web-redirect
Javier Contreras
it as posted yesterday
regards
Javier Contreras
hi Nilay
I would recommend 8.0.120.0, as it carries over most of the 8.0Esc fixes. if you want "tried and tested" code, 8.0.110.14 or .16 would be code that has been exposed to large different environments/customers
regards
vyas.nilay
Level 3
Level 3
Thanks Javier,
How do I download 8.0.110.16 code?
I have seen compatibility matrix for 8.1 AirOs and it shows certain IOS requires on access points.
Is that the case and if so Do I have to upgrade it to all the access points including 1142 ?
Kind Regards,
Nilay Vyas.
Javier Contreras
hi
8.0.110.x is available through a TAC case
you don't need to upgrade the APs beforehand, if you are on the supported upgrade path
(for 8.0, it is 7.0.98.0 and higher, it is detailed on the release notes)
regards
gohussai
Level 8
Level 8
Try using the old stable release unless new version proven to be bug free before doing proper upgrade to your LAPs.
ralphfowler
Javier-
So is the 8.0.120.0 (ED) that is on the web site considered the to be 8.0 MR2? Is this the recommended load to go with if we want something stable right now that needs to be Rls 8?
I need to move something Rls 8 into my lab for testing and deployment in August.  I haven't heard of an 8.0 MR3 in the works.
thanks
Javier Contreras
yes
it is already on planning phase
regards
