Hamed Fazel
If you're looking to automate network device configuration using Python, there are several powerful libraries and tools available. Below is a summary of some key options:
LibraryConnection Data ModelDevices Support
YDK-PySSH, NETCONFYANGAll devices supporting YANG
NAPALMSSH, NETCONF, XMLYANGArista EOS, Cisco IOS, Cisco IOS-XR, Cisco NX-OS, Juniper JunOS
NetmikoSSHNo data model uses CLIAny device that supports SSH
PyEZSSH, NETCONFYANGJuniper devices
Key Highlights:
  • YDK-Py: A Python library developed by Cisco, providing APIs that abstract YANG models, making it easier to interact with devices supporting YANG data models.
  • NAPALM: A multi-vendor library that supports several connection types and offers a consistent API across various platforms.
  • Netmiko: A simplified Python library for SSH connections to network devices, ideal for CLI-based automation.
  • PyEZ: A Python library tailored for Juniper devices, supporting YANG models and NETCONF protocol for a more structured configuration approach.
Each tool has its strengths, depending on the type of devices you're working with and the level of abstraction you need. Whether you're dealing with complex YANG models or simply automating CLI commands, these libraries offer flexible solutions for network automation.
kkowalczyk
Community Member
I use a package called CiscoAutomationFramework for interacting with Cisco devices.
https://github.com/superadm1n/CiscoAutomationFramework
I find it the most useful due to the parsers integrated which allows you to analyze configuration and generate change configuration based on the devices current configuration state. It also gives integrated ways of taking output of the device, parsing it, and giving it to you in a data structure in Python, for instance you can just get a list of the interfaces in a list versus needing to issue commands and parse that yourself.
