TCC_2
Level 10
Level 10
Resolution
Each CiscoWorks version supports only a very specific set of browsers.
If you are using an unsupported browser, the application shows various deviations.
To resolve this issue, perform these steps:
  1. Check which browsers are supported in your version by referring to CiscoWorks Compatibility Matrix.
  2. If your browser is unsupported, retry your operation with a supported version.
