Satwinder81
Hi all
I have recently bought a router Cisco ASR 1000 series(1001) with IOS 15.1.
I am facing a problem while configuring ssh and snmp.
It is not accepting the configuration commands of ssh and snmp and refusing a connection.
I have tried a lot but still not got the solution.
Could u pls help me.
regards
Satwinder(new delhi)
susdas
Hi Satwinder
Could you please get me the output of 'show version'?
Kindly refer to the following document for SSH configuration:
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_usr_ssh/configuration/xe-3s/sec-usr-ssh-xe-3s-book.pdf
Could you specify which command is not working in SNMP on your ASR box?
Sush
