fcolumbu
This configuration is used with “Introduction to the Cisco 5921 Embedded Services Router v1” in dCloud.
Derived from:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/867-cisco-router-site-to-site-ipsec-vpn.html
Lines in BOLD ORANGE are changes made to the existing configuration to do the lab exercise.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.11.21 23:16:28 =~=~=~=~=~=~=~=~=~=~=~=
c5921_ubuntu32_2#wr t
Building configuration...
Current configuration : 5052 bytes
! Last configuration change at 22:46:05 PST Sat Nov 21 2015
! NVRAM config last updated at 22:49:44 PST Sat Nov 21 2015
version 15.5
service call-home
hostname c5921_ubuntu32_2
boot-start-marker
boot-end-marker
enable secret 5 $1$x.6O$4UZX1B5lYLF1DeOul7GiV1
enable password cisco
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone PST -8 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
call-home
! if contact email address in call-home is configured as sch-smart-licensing@cisco.com
! The email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
  active
  destination transport-method http
  no destination transport-method email
ip name-server 8.8.8.8
ip cef
no ipv6 cef
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
  30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
  32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
  6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
  3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
  43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
  526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
  82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
  CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
  1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
  4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
  7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
  68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
  C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
  C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
  DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
  06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
  4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
  03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
  604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
  D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
  467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
  7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
  5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
  80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
  418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
  D697DF7F 28
  quit
license udi pid CISCO5921-K9 sn 95O9000IL4J
license platform throughput level c5921-x86-level3
redundancy
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key cisco123 address 172.23.1.120
crypto ipsec transform-set myset esp-3des esp-md5-hmac
mode tunnel
crypto map CMAP 10 ipsec-isakmp
set peer 172.23.1.120
set transform-set myset
match address VPN-TRAFFIC
interface Loopback0
ip address 10.0.0.121 255.255.255.255
interface Loopback1
description Inside interface
ip address 10.2.2.2 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Ethernet0/0
description Outside interface
ip address 172.23.1.121 255.255.255.0
ip nat outside
duplex full
speed 1000
no mop enabled
crypto map CMAP
interface Ethernet0/1
ip address 172.23.2.2 255.255.255.0
shutdown
duplex full
speed 1000
interface Ethernet0/2
ip address 172.23.3.2 255.255.255.0
shutdown
duplex full
speed 1000
interface Ethernet0/3
ip address 172.23.4.2 255.255.255.0
shutdown
duplex full
speed 1000
router ospf 100
network 10.0.0.0 0.255.255.255 area 0
network 172.23.1.0 0.0.0.255 area 0
network 172.23.2.0 0.0.0.255 area 0
network 172.23.3.0 0.0.0.255 area 0
network 172.23.4.0 0.0.0.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Loopback1 overload
ip access-list extended VPN-TRAFFIC
permit ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
snmp-server community public RO
access-list 100 remark -=[Define NAT Service]=-
access-list 100 deny   ip 10.2.2.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
transport input all
ntp server 198.18.134.132
end
c5921_ubuntu32_2#show crypto session
Crypto session current status
Interface: Ethernet0/0
Session status: UP-ACTIVE
Peer: 172.23.1.120 port 500
  Session ID: 0
  IKEv1 SA: local 172.23.1.121/500 remote 172.23.1.120/500 Active
  IPSEC FLOW: permit ip 10.2.2.0/255.255.255.0 10.1.1.0/255.255.255.0
        Active SAs: 2, origin: crypto map
c5921_ubuntu32_2#show crypto isakmp sa detail
Codes: C - IKE configuration mode, D - Dead Peer Detection
       K - Keepalives, N - NAT-traversal
       T - cTCP encapsulation, X - IKE Extended Authentication
       psk - Preshared key, rsig - RSA signature
       renc - RSA encryption
IPv4 Crypto ISAKMP SA
C-id  Local           Remote          I-VRF  Status Encr Hash   Auth DH Lifetime Cap.
1001  172.23.1.121    172.23.1.120           ACTIVE aes  md5    psk  2  23:01:28
       Engine-id:Conn-id =  SW:1
IPv6 Crypto ISAKMP SA
c5921_ubuntu32_2#show crypto  ipsec sa
interface: Ethernet0/0
    Crypto map tag: CMAP, local addr 172.23.1.121
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.2.2.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (10.1.1.0/255.255.255.0/0/0)
   current_peer 172.23.1.120 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 14, #pkts encrypt: 14, #pkts digest: 14
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 172.23.1.121, remote crypto endpt.: 172.23.1.120
     plaintext mtu 1446, path mtu 1500, ip mtu 1500, ip mtu idb Ethernet0/0
     current outbound spi: 0x2AB1BE70(716291696)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0xB0387DB6(2956492214)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Tunnel, }
        conn id: 3, flow_id: SW:3, sibling_flags 80000040, crypto map: CMAP
        sa timing: remaining key lifetime (k/sec): (4348059/3470)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 4, flow_id: SW:4, sibling_flags 80000040, crypto map: CMAP
        IV size: 8 bytes
     outbound ah sas:
     outbound pcp sas:
c5921_ubuntu32_2#show ver
Cisco IOS Software, C5921 Software (C5921_I86-UNIVERSALK9-M), Version 15.5(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 25-Mar-15 15:49 by prod_rel_team
ROM: Bootstrap program is Linux
c5921_ubuntu32_2 uptime is 1 hour, 12 minutes
System returned to ROM by reload at 0
System restarted at 22:04:33 PST Sat Nov 21 2015
System image file is "unix:./c5921i86-universalk9-ms.SPA"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C5921 (Intel-x86) processor with 381075K bytes of memory.
Processor board ID 100
4 Ethernet interfaces
512K bytes of NVRAM.
License Info:
License UDI:
Device#  PIDSN
*0    CISCO5921-K9          95O9000IL4J
Packet forwarding: Enabled
Enforced traffic rate: 50 Mbps
Configuration register is 0x0
c5921_ubuntu32_2#
fcolumbu
Please restore these pages ASAP.
