Paul Zimmerman
Interested in learning how to use REST APIs for SD-WAN? Please check out this webinar from Developer Advocate and networking expert Adrian Iliesiu.
In this webinar, we will have a look at what REST APIs are and how they can be used to interact programmatically with Cisco SD-WAN. We will also briefly cover Cisco SD-WAN, how the WAN has evolved to Software-Defined WAN, what are the components and benefits of a Cisco SD-WAN fabric, and how to use the vManage REST API interface to configure, manage and monitor your own fabrics.
CHECK-OUT More Webinars and Workshops at https://blogs.cisco.com/developer/sdwanautomationmonth01
CISCO DEVELOPER SD-WAN resources can be found at
Developer Hub - https://developer.cisco.com/sdwan/
API Docs - https://developer.cisco.com/docs/sdwan/
Find Adrian across the internet at...
Twitter - https://twitter.com/aidevnet
LinkedIn - https://www.linkedin.com/in/adrian-i-6604bb3/
Twitch - https://twitch.tv/ciscodevnet
Cisco Developer Blog - https://blogs.cisco.com/author/adrianiliesiu
