ashirkar
Level 7
Level 7
Introduction:
In this document we will see Comparision of basic Static route Configuartion between cisco IOS and IOS XR.
Configuration Example:
In this example we have R1 running Cisco IOS and PE1 IOS XR.
In IOS XR static route is configure under router subsection called "router static”. Static route can point to a next-hop interface, next-hop IP address, or both. In this example we have pointed to both next-hop IP address as well to interface.
R1PE1
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#
*May  6 16:12:52.187: %SYS-5-CONFIG_I: Configured from console by console
R1(config)#ip route 1.1.1.1 255.255.255.255 fa0/0 10.1.1.1
R1(config)#do wr
Building configuration...
[OK]
R1(config)#
RP/0/0/CPU0:PE1#conf t
Mon May  6 10:42:14.853 UTC
RP/0/0/CPU0:PE1(config)#router static
RP/0/0/CPU0:PE1(config-static)#address-family ipv4 unicast
RP/0/0/CPU0:PE1(config-static-afi)#1.1.1.1/32
gig0/0/0/1 10.1.1.1
RP/0/0/CPU0:PE1(config-static-afi)#commit
Mon May  6 10:42:39.561 UTC
You can also use floating route as well enable permant option to static route as shown below:
R1PE1
R1#conf t
R1(config)#ip route 1.1.1.1 255.255.255.255 fa0/0 10.1.1.1 permanent 200
R1(config)#end
R1#wr
[OK]
R1#
gig0/0/0/1 10.1.1.1 permanent 200
To configure IPv6 static route you just need to change address-family as show below:
IPv6 static route:
R1PE1
R1#conf t
R1(config)#ipv6 route 2001:1:1:1::/64 fa0/0 fe80::2
R1(config)#end
R1#wr
[OK]
R1#
Mon May  6 12:38:55.043 UTC
RP/0/0/CPU0:PE1(config-static)#address-family ipv6 unicast
RP/0/0/CPU0:PE1(config-static-afi)#2001:1:1:1::/64 gig0/0/0/1 fe80::1
Mon May  6 12:39:31.311 UTC
You can also specify Static route for VRF instance. The VRF can be the default VRF or a specified VRF. Specifying a VRF, using the vrf vrf-name command, allow you to enter VRF configuration mode for a specific VRF where you can configure a static route. If a VRF is not specified, a default VRF static route is configured.
R1
PE1
R1#conf t
R1(config)#ip route vrf Cust_A 1.1.1.1 255.255.255.255 10.1.1.2
R1(config)#do wr
[OK]
R1(config)#end
R1#
Sun May 5 16:22:45.272 UTC
RP/0/0/CPU0:PE1(config)#router static vrf Cust_A
RP/0/0/CPU0:PE1(config-static-vrf)#address-family ipv4 unicast
RP/0/0/CPU0:PE1(config-static-vrf-afi)#1.1.1.1 255.255.255.255 10.1.1.2
RP/0/0/CPU0:PE1(config-static-vrf-afi)#commit
Sun May 5 16:23:29.529 UTC
RP/0/0/CPU0:PE1(config-static-vrf-afi)#end
RP/0/0/CPU0:PE1#
Verification:
You can verify your static route configuration there is only single command you can use to verify IPv4/IPv6 and specific VRF route as shown below.
R1
PE1
R1#sh ip route static
R1#sh ip route vrf Cust_A static
R1#sh ipv6 route static
P/0/0/CPU0:PE1#sh running-config router static
Mon May  6 13:10:22.244 UTC
router static
  1.1.1.1/32 10.1.1.2
  1.1.1.1/32 GigabitEthernet0/0/0/1 10.1.1.1 200 permanent
  2001:1:1:1::/64 GigabitEthernet0/0/0/1 fe80::1
vrf Cust_A
   1.1.1.1/32 GigabitEthernet0/0/0/2
RP/0/0/CPU0:PE1#
Related Information:
Implementing Static Routes on Cisco IOS XR Software
Can you explain me why in my conf if I configure a static route on IOS-XR 5.2.2
router static
vrf BGP-GREEN
10.0.10.0/24 2.2.2.2
I cannot see it in routing table?
RP/0/0/CPU0:ASBR-11#sh route vrf BGP-GREEN
B 10.0.10.0/24 [200/2] via 2.2.2.2 (nexthop in vrf default), 00:24:32
C 192.168.17.0/30 is directly connected, 00:25:30, GigabitEthernet0/0/0/2.10
L 192.168.17.1/32 is directly connected, 00:25:30, GigabitEthernet0/0/0/2.10
Found by my own:
It wanted the "vrf default" for the next hop (10.0.10.0/24 vrf default 2.2.2.2)
