info
Community Member
I have a cisco 877w with the following configuration
version 12.4
no service pad
hostname thermi
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$Q0rs$PD6wVRgb469SE1ghXjbQ.0
no aaa new-model
resource policy
clock timezone Athens 2
clock summer-time Athens date Mar 30 2003 3:00 Oct 26 2003 4:00
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.200.1 192.168.200.170
ip dhcp excluded-address 192.168.200.180 192.168.200.254
ip dhcp excluded-address 192.168.102.1 192.168.102.170
ip dhcp pool ThermiPool
   import all
   network 192.168.200.0 255.255.255.0
   dns-server 195.170.2.2 195.170.0.1
   default-router 192.168.200.1
   lease infinite
ip dhcp pool sdm-pool1
   network 192.168.102.0 255.255.255.0
   default-router 192.168.102.1
ip domain name thermi.gr
ip name-server 195.170.2.2
ip name-server 195.170.0.1
crypto pki trustpoint TP-self-signed-3913487588
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3913487588
revocation-check none
rsakeypair TP-self-signed-3913487588
crypto pki certificate chain TP-self-signed-3913487588
certificate self-signed 01
  30820248 308201B1 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393133 34383735 3838301E 170D3032 30333031 30313433
  30335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39313334
  38373538 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B99F 2BD2C197 453F8BEE B0AC6D92 24AC1FE7 E7369775 982AD871 558D4D39
  BD1C4F1D 14E8F8C3 07159B07 5AF60626 91078E10 A8595C0B 51DCFCA0 65A7C92E
  1A470716 9DCFC52C A91F26EB 5CBBBCC9 4AA8243B 6AB08721 32087711 F884C5CC
  F74DED84 5761C885 4BBF486A F3009EC9 7B3586B5 01EFCF3E 14FE851A 66362324
  12C10203 010001A3 70306E30 0F060355 1D130101 FF040530 030101FF 301B0603
  551D1104 14301282 10746865 726D692E 74686572 6D692E67 72301F06 03551D
  04183016 8014E6AA 049E74E8 AA9A6BAD BDF737D7 53C8637A 91A1301D 0603551D
  0E041604 14E6AA04 9E74E8AA 9A6BADBD F737D753 C8637A91 A1300D06 092A8648
  86F70D01 01040500 03818100 097967A4 C2E556CA B978785F 8EF580D6 F702E317
  05213B63 3DFD9983 267FD874 76AA6149 20E9C894 B7E921E1 240B9FFA 52D81D39
  5E4600CE 8B4F62B3 F5C1638E E33C69F1 8DF0EF36 DF8DBE58 9F65CC4B 401128A3
  A87D938F 31319CFA F787D448 BFA5087D E3459178 F2C86805 5F776596 76A412EE
  9520D77B B3F32322 7B3A2D8E
  quit
username admin privilege 15 password
archive
log config
  hidekeys
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
ip virtual-reassembly
encryption vlan 1 key 1 size 128bit 0 12345678901234567890ABCABC transmit-key
encryption vlan 1 mode wep mandatory
ssid thermi
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 b
asic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip nat inside
ip tcp adju
bridge-group 1
interface Vlan2
ip address 192.168.102.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxxxxxxx
ppp chap password 0 yo5c-tu
ppp pap sent-username xxxxxxxxxxx password yyyyyyyyyyy
interface BVI1
ip address 192.168.200.1 255.255.255.0
ip nat ins
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip nat inside source static udp 192.168.200.101 69 interface Dialer0 69
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.200.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community public RO
no cdp run
route-map SDM_RMAP_1 permit 1
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
password 100
login
transport input telnet
transport output telnet
scheduler max-task-time 5000
end
I cannot find out why the wireless software and hardware are down.
Thank you.
Tasos G. Papafilakis
cindy toy
Level 9
Level 9
Hi Tasos,
Please repost this as a discussion instead of a document.
Cindy Toy
Small Business Community Manager
Leo Laohoo
Where's your SSID config?
