Santosh Sharma
EEM script to save logs in a file every 30 mins
Problem:
The router is having an issue where we are unable to login to the router using console or mgmt ports. Other components of router is working fine. RSP reload is the only way we can get access to the router.
Since the access to router is disabled we cannot login to the router in order to collect the logs to debug this issue further.
Solution:
We can use EEM script inorder to collect the logs and save it into a file in harddisk. This EEM script will run every 30 mins and dump the logs into the file. The cron entry can be changed incase we want to run it once every day or some other period.
Logs that the script collects:
show proc devc-vty
show proc devc-conaux
show log
sh processes cpu
Show users
Show line
Router's config:
event manager environment _cron_entry 30,0 * * * 0-6    <<<<< runs script every 30 mins
event manager directory user policy harddisk:/scripts/
event manager policy eem_run_30_min.tcl username event_manager_user
persist-time 3600
group root-system
group cisco-support
aaa authorization commands eem-method none
aaa authorization eventmanager default local
vty-pool eem 100 105 line-template eem-template
  line template eem-template
More Scripts: EEM Script Repository
sqamar
Nice and simple document
