Meddane
Download below EIGRP PDF Document with 22 scenarios I used in the past for my certification preparation with the following content, these scenarios are useful to prepare the CCNP Enterprise ENARSI exam:
Lab 1: EIGRP Different AS Distribute-List Offset List
Lab 2: Redistribution between two AS EIGRP Variance and Offset-List
Lab 3: EIGRP redistribution between two AS and the next-hop field
Lab 4: EIGRP route filtering using prefix-list and route-map
Lab 5: EIGRP Route Filtering using Route-Map Prefix-List ACL
Lab 6: EIGRP Route Leaking Maximum hop-count
Lab 7: EIGRP Default Route Summarization Authentication
Lab 8: EIGRP Named Mode for IPv4 and IPv6
Lab 9: EIGRP named mode over IPv6
Lab 10: EIGRP Named Mode Authentication
Lab 11: EIGRP Stub Routing with Named Mode
Lab 12: Maximum-prefix limit and Warning-Only Mode
Lab 13: Two EIGRP AS number and two equal paths to the same destination
Lab 14: Feasible Successor issues
Lab 15: EIGRP Summary and Leak Map
Lab 18: show ip eigrp topology all-links subcommand
Lab 19: Successor and Feasible Successor
Lab 20: Next-hop field between two AS eigrp IPv6
Lab 21: Filter EIGRP external routes
Lab 22: EIGRP Stub Feature
siskum
Thanks for sharing this document. I downloaded it
/Sisira
Meddane
@siskum  you are welcome
Martin L
Thanks; looks good; is this based on exam blueprint? exam itself? something else ?
Meddane
Yes and it's going in details.
sulmen
I appreciate you sharing this.  It is JUST what I was looking for!
