Mahabir Prasad
Following is how we can retrieve and interpret sensor (power, voltage, current) of a slot/port via SNMP
For example this is the CLI output from 6500 and we want to monitor tx/rx power for Te2/4
#sh interface transceiver detail
Optical            High Alarm  High Warn  Low Warn   Low Alarm
            Transmit Power     Threshold   Threshold  Threshold  Threshold
Port        (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te2/1         N/A                 4.4         0.4        -8.2      -12.2
Te2/2        -2.5                 2.9        -1.0        -7.3      -11.3
Te2/3         N/A                 4.4         0.4        -8.2      -12.2
Te2/4        -1.9                 4.4         0.4        -8.2      -12.2
Te2/5        -2.5                 4.4         0.4        -8.2      -12.2
Te2/6        -2.9                 2.9        -1.0        -7.3      -11.3
Te2/7        -2.6                 2.9        -1.0        -7.3      -11.3
            Receive Power      Threshold   Threshold  Threshold  Threshold
Te2/1         N/A                 4.4         0.4       -14.4      -18.4
Te2/2        -2.5                 2.9        -1.0        -9.9      -13.9
Te2/3         N/A                 4.4         0.4       -14.4      -18.4
Te2/4        -8.5                 4.4         0.4       -14.4      -18.4
Te2/5        -8.0                 4.4         0.4       -14.4      -18.4
Te2/6        -3.4                 2.9        -1.0        -9.9      -13.9
Te2/7        -3.0                 2.9        -1.0        -9.9      -13.9
Step 1: We need to poll 1.3.6.1.2.1.47.1.1.1.1.2 (entPhysicalDescr) which is part of ENTITY-MIB. This will provide us index and descriptoin of particular sensor which we want to monitor.
Partial output of snmpwalk of 1.3.6.1.2.1.47.1.1.1.1.2 shown below:
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2022 = STRING: "TenGigabitEthernet2/1 Transmit Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2023 = STRING: "TenGigabitEthernet2/1 Receive Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2035 = STRING: "TenGigabitEthernet2/2 Transmit Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2036 = STRING: "TenGigabitEthernet2/2 Receive Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2061 = STRING: "TenGigabitEthernet2/4 Transmit Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2062 = STRING: "TenGigabitEthernet2/4 Receive Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2074 = STRING: "TenGigabitEthernet2/5 Transmit Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2075 = STRING: "TenGigabitEthernet2/5 Receive Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2087 = STRING: "TenGigabitEthernet2/6 Transmit Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2088 = STRING: "TenGigabitEthernet2/6 Receive Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2100 = STRING: "TenGigabitEthernet2/7 Transmit Power Sensor"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.2101 = STRING: "TenGigabitEthernet2/7 Receive Power Sensor"
Red highlighted values are indexes of sensors we are interested in.
STEP 2: SNMPWALK of 1.3.6.1.4.1.9.9.91.1.1.1.1.4 (entSensorValue) which is part of CISCO-ENTITY-SENSOR-MIB
Partial output of snmpwalk of 1.3.6.1.4.1.9.9.91.1.1.1.1.4 shown below:
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2022 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2023 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2035 = INTEGER: -25
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2036 = INTEGER: -25
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2061 = INTEGER: -19
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2062 = INTEGER: -85
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2074 = INTEGER: -25
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2075 = INTEGER: -80
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2087 = INTEGER: -29
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2088 = INTEGER: -34
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2100 = INTEGER: -26
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2101 = INTEGER: -30
STEP 3: Interpret values
For interpreting values we need to poll below: entSensorType , entSensorScale and entSensorPrecision. Description of these objects given below:
.1.3.6.1.4.1.9.9.91.1.1.1.1.1
entSensorType OBJECT-TYPE
        -- FROM CISCO-ENTITY-SENSOR-MIB
        -- TEXTUAL CONVENTION SensorDataType
        SYNTAX         Integer { other(1), unknown(2), voltsAC(3), voltsDC(4), amperes(5), watts(6), hertz(7), celsius(8), percentRH(9), rpm(10), cmm(11), truthvalue(12), specialEnum(13), dBm(14) }
        MAX-ACCESS     read-only
        STATUS         Current
        DESCRIPTION    "This variable indicates the type of data
        reported by the entSensorValue.
.1.3.6.1.4.1.9.9.91.1.1.1.1.2
entSensorScale OBJECT-TYPE
        -- TEXTUAL CONVENTION SensorDataScale
        SYNTAX         Integer { yocto(1), zepto(2), atto(3), femto(4), pico(5), nano(6), micro(7), milli(8), units(9), kilo(10), mega(11), giga(12), tera(13), exa(14), peta(15), zetta(16), yotta(17) }
        STATUS         Current
        DESCRIPTION    "This variable indicates the exponent to apply
        to sensor values reported by entSensorValue.
        This variable is set by the agent at start-up
        and the value does not change during operation."
1.3.6.1.4.1.9.9.91.1.1.1.1.3
entSensorPrecision OBJECT-TYPE
        -- TEXTUAL CONVENTION SensorPrecision
        SYNTAX         Integer (-8..9)
        STATUS         Current
        DESCRIPTION    "This variable indicates the number of decimal
        places of precision in fixed-point
        This variable is set to 0 when entSensorType
        is not a fixed-point type:  voltsAC(1), voltsDC(2),
        amperes(3), watts(4), hertz(5), celsius(6), or cmm(9).
Now for example we have to interpret values for transmit and receive power of TE2/4. So
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.1.2061 = INTEGER: 14                            -----> means dBm
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.2.2061 = INTEGER: 9                              -----> means units
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.3.2061 = INTEGER: 1                              -----> number of decimal place is one
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.2061 = INTEGER: -19                          -----> after placing decimal after one integer value is -1.9 dBm which is actual value
Note:
On nexus entityPhysicalIndex are not supported for slot/port which are required to make correlation between interface and entitySensorValue.
Enhancement request (CSCty93934) for nexus 7k and  (CSCui73423) for nexus 5k is opened.
agallegos
Community Member
Great help thanks!
I´m looking also for High Alarm, High Warn,Low Warn and Low Alarm Thresholds, but can´t find the OIDs. How could I manage with that?
agallegos
Community Member
Answering myself.
OID should be
iso.3.6.1.4.1.9.9.91.1.2.1.1.4
We can see for a single interface, 4 indexes (RX or TX).
iso.3.6.1.4.1.9.9.91.1.2.1.1.4.2061.1 = INTEGER: 15
iso.3.6.1.4.1.9.9.91.1.2.1.1.4.2061.2 = INTEGER: 794
iso.3.6.1.4.1.9.9.91.1.2.1.1.4.2061.3 = INTEGER: 10
iso.3.6.1.4.1.9.9.91.1.2.1.1.4.2061.4 = INTEGER: 1258
where:
.1 Low Warning
.2 High Warning
.3 Low Alarm
.4 High Alarm
The format should be the same as SensorValue
