Sutheendiran Vijendiran
Cisco SD-WAN Version 20.6.3 offers major usability benefits across all use cases.  There are enhancement to SD-WAN Infrastructures, SDCI and SD-WAN Security, with innovation and Improvement around Cloud Networking, Operational Efficiency and Application Experiences.
We have put together the table below to give you a quick look at some of the key features in this release.
Feel free to ask any questions about upgrading your Cisco SD-WAN software using the "comment" section below the post.
If you want to stay up to date with our Software Compliance and key feature articles make sure to subscribe to the label 'Software Upgrades'!
Capability
Feature​​​
Description​
Pre 20.6.3.1​
vManage
SDWAN UX2.0-Phase 1-Cohesion Design ​
UX 2.0 Day-0 Quick Connect workflow enables you to create device templates to onboard Wan Edge devices with ZTP/PnP, and to generate bootstrap CLI configuration. It is a new, user-friendly UI and intuitive workflow.​
Previously, ​you didn’t have a very intuitive vManage GUI workflow, which makes the Day-0 SD-WAN onboarding difficult with an outdated GUI. ​
ThousandEyes integration w/ ISR4K, Cat8300, Cat8200 ​
With ThousandEyes Integration, vManage can deploy and provision agent software on the router itself. You can even monitor the underlay of SD-WAN fabric, which helps isolate/fix issues quickly.​
Previously, ​to monitor your network, you were forced to host the agent software on an external x86 appliance, which can be hard to manage, and so is also the case for any additional equipment within the branch.​
Core & Infra​​
6+ SLA classes support ​
Having 6+ SLA classes per policy gives you additional options in App-Aware Routing. The SLA enhancement also facilitates multi-tenancy deployment, allowing you to push different SLA classes for different tenants. ​
Previously, you weren’t able to create more than 6 SLA classes on a policy for your application, which leads you to create a larger number of policies in the fabric and complicates policy management. ​
  1. Per VPN QoS ​
  2. Service-Side Port Channels ​
  1. This enhanced version of the QoS feature brings another layer of support to traffic throughput on per-VPN basis and delivers various QoS services used on one interface for different VPNs.​
  2. Port channels are now available, providing fault-tolerance and traffic redistribution across the remaining links, if any link fails. It also helps increase bandwidth between Cisco IOS XE SD-WAN devices and others such as switches and servers in the network.​
  1. Previously, ​you were restricted to use 2 QoS modules, (Adaptive and per-tunnel), which leads all service VPN traffic to utilize the same SD-WAN resources/bandwidth. ​
  2. Previously, you didn’t have a feature to do link aggregation in your environment with any Layer 3 devices, which leads to low resiliency and limits bandwidth usage.​
Services
  1. Cisco SD-WAN SDCI w/ Megaport (Azure and  GCP Support)  ​
  2. Equinix (AWS Support, Site to Site Support) ​
  1.  You can deploy a Cisco Catalyst 8000v as the interconnect gateway in the Megaport fabric and connect your SD-WAN branch location. From there, you can create Software Defined Cloud Interconnect to Google and Microsoft Azure Cloud to link your branch location to the cloud resources through the Megaport fabric. ​
  2. Similarly, the Catalyst 8Kv can be deployed as the interconnect gateway in the Equinix fabric, allowing you to create SD interconnect to an AWS Cloud or another in the Equinix fabric. ​
  1. Previously, ​there was Megaport support only for AWS Cloud, which limits the customer options to explore other CSPs. ​
  2. As for Equinix, there was no support at all. ​
  1. CoR over SIG tunnels​
  2. Layer 7 health check to Umbrella ​
  1. CloudOnRamp over SIG tunnels provides the best path performance for your SaaS applications.​
  2. L7 health check will be enabled by default for all SIG auto-tunnels to monitor latency and reachability based on HTTP request and response probes to a URL that is reachable through the SIG tunnels. This allows you to fail over to an alternate tunnel when reachability fails, or latency degrades beyond an acceptable threshold.​
  1. Previously, ​you didn't have a Secure Internet Gateway for your SaaS applications with CloudOnRamp.​
  2.  Previously, you weren't able to monitor the IPsec tunnel health to detect brown outs and dynamically influence traffic forwarding based on high performing tunnels. ​
Reference:
20.6.3 x Release notes
What's New with 20 6 3 x
Cisco’s SD-WAN Controller Compatibility Matrix
SD-WAN release 20.6.3.1 release download
lauvtoronto
Beginner
Beginner
Thanks for the detailed information.
neelrupani3179
Beginner
Beginner
Any improvement in vbond , vmanage ?
Andrei Sidorkov
Beginner
Beginner
Thank you for sharing! Great news that you starting to support Azure integration.
Unfortunately we don’t use sd-wan .
rendy.rinaldy
Beginner
Beginner
Thank for update, We will discussion with our engineer
Felipe Patino
Beginner
Beginner
Muy interesante. La parte del networking en la nube parece demasiado atractivo.
juanchicaiza
Beginner
Beginner
Thanks for sharing the information , the new feature for vpn is very well the QoS.
Paulo Thame
Beginner
Beginner
We do not use Cisco SD-WAN yet, as we get an optical link between the locations.
Atif Raees
Beginner
Beginner
very usefull feature brief.
davidpeck
Enthusiast
Enthusiast
Nice summary and thanks for sharing the information. It's nice to see Cisco still pushing this technology forward.
JRD
Beginner
Beginner
Great job!
Matienzo
Beginner
Beginner
Great Gob!
Thank you for sharing:)
Anil Patil
Collaborator
Collaborator
Thank you for detail information.
ivden
Beginner
Beginner
Excellent overview!
Thank you for the awesome overview!
Recognize Your Peers
