Meddane
In OSPFv3 the LSA Type 9 has an impact to save CPU utilization by avoiding a frequent triggering of SPF when running OSPFv3, to see the important role of this LSA Type 9, i I did two scenarios:
1-The first scenario with OSPFv2, I investigate and compare the LS age and Sequence Number of the LSA Type 1 of R1, and the Number of SPF algorithm executed before and after adding a new ip address on R1.
2-The second scenario with OSPFv3, I investigate and compare the LS age and Sequence Number of the LSA Type 1 's R1 and the LSA Type 9 's R1, and the Number of SPF algorithm executed before and after adding a new ip address on R1.
