jsalinasf
Community Member
Good Morning.
I'm trying to access from outside the office to my camera server inside.
I'm trying with NAT in this way:
ip nat inside source static tcp 192.168.1.200 37777 interface Dialer0 37777
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 110 remark Camara-inside
access-list 110 remark CCP_ACL Category=16
access-list 110 remark Camaras-in
access-list 110 permit tcp any eq 37777 host 192.168.1.200 eq 37777 established log
dialer-list 1 protocol ip permit
But there's no luck.
Does anyone can help me ?
Thank you very much in advance.
Jose Salinas
Hi Jose.
Does ACL 110 is assign to interface outside ?
If yes , you have to change it on :
access-list 110 permit tcp any eq 37777 interface Dialer0 eq 37777
interface Dialer0
ip addrress .....
ip access-group 110 in
ip nat outside
jsalinasf
Community Member
Thank you very much Robert.
The problem was that had a bad gateway in the camera webserver.
Now it's solved.
Than you very very much
