TCC_2
Level 10
Level 10
Core Issue
The configuration register is probably set to a value that enables the break key in normal operation.
Resolution
Issue the config-register command to change the configuration register to a value that disables the break key. The most common value is 0x2102.
For more information, refer to What Causes a Router To Be Restarted By the Abort or Trace Trap Commands.
