Abdu
Routing Information Protocol (RIP) is one of the oldest and most straightforward interior gateway protocols (IGP) used in computer networking. Initially developed in the 1980s, RIP has undergone several revisions, with the most widely used version being RIP version 2 (RIPv2). This article aims to provide a comprehensive overview of the RIP protocol, its history, operation, and its relevance in modern networking environments.
History of RIP:
RIP was initially developed by Dr. Charles Hedrick and was introduced as part of the Xerox Network Systems (XNS) protocol suite. The protocol was later adapted for use in the Internet Protocol (IP) environment. The original RIP, known as RIP version 1 (RIPv1), had limitations such as a maximum hop count of 15 and the absence of support for subnetting. In response to these limitations, RIP version 2 (RIPv2) was introduced, which addressed these issues and provided additional features.
Operation of RIP:
RIP operates as a distance-vector routing protocol, which means that routers exchange routing information with their neighbors, and each router makes decisions based on the distance (metric) to reach a destination. The metric used by RIP is typically the hop count – the number of routers that must be traversed to reach a particular destination.
Key features of RIP:
  1. Hop Count Metric:
    • RIP uses a simple hop count metric to determine the best path to a destination. Each router in the network maintains a routing table that contains information about the number of hops to reach each destination.
  2. Routing Updates:
    • RIP routers periodically broadcast routing updates to their neighboring routers. These updates contain information about the network's topology, including reachable destinations and their associated hop counts.
  3. Split Horizon:
    • To prevent routing loops, RIP uses a technique called split horizon. This means that a router does not advertise routes back through the interface from which it received the route information.
  4. Route Poisoning:
    • When a route becomes unreachable, RIP uses route poisoning to inform other routers about the change. The unreachable route is advertised with an infinite metric, indicating that the route should not be used.
  5. Authentication (RIPv2):
    • RIP version 2 introduced support for authentication to enhance security. This helps in preventing unauthorized routers from injecting false routing information into the network.
Relevance in Modern Networks:
While RIP has been largely replaced by more advanced routing protocols like OSPF (Open Shortest Path First) and EIGRP (Enhanced Interior Gateway Routing Protocol) in large and complex networks, RIP is still used in smaller networks or as a legacy protocol in certain environments. Its simplicity makes it easy to configure and deploy, especially in scenarios where more advanced routing protocols might be unnecessary.
Arman witty
Visitor
What is hop count
Joseph W. Doherty
What is hop count
A hop is crossing between L3 networks, such as crossing between classful networks 192.168.1.0 and 192.168.2.0.  The hop count is the number of times this happens between source and destination networks along a particular/specific path.   In the just previously described two networks, the hop count would be 1.
Arman witty
Visitor
Like how many switch are there or other devices through which data must be passed and the best way is the one with less number of hop counts
Joseph W. Doherty
Correct, best path is the lowest count, but it's not a just a count of switches or other physical devices. Again, there needs to be a L3 network transition.  For example, L2 switch transitions are not counted, and even crossing routers, if in a tunnel, are not counted.
