Joe Clarke
Here are two EEM Tcl policies that work in concert to track ports that are operationally down for a given period of time.  If they are down long enough, then the ports are administratively shutdown (or placed in a quarantine VLAN if said VLAN is defined) to prevent unknown or untracked use of them.  Each policy uses some EEM environment variables.  For the timer policy:
# This policy runs at a configured time, then checks to see if inactive ports
# have been inactive for a configured amount of time.  If so, then the ports
# will be shutdown.
# This policy uses the following environment variables:
# suspend_ports_days        : Number of days before a port is suspended.
# suspend_ports_config      : Path to configuration file.
# suspend_quarantine_vlan   : (optional) VLAN number into which ports will be moved
#                             instead of being shutdown.  If not defined, ports will be
#                             shutdown.
And for the syslog policy:
# This policy listens for link up syslog messages, and removes the port from
# the list of down ports.
Nisterio
Five Year Later, I have discovered the "ancient script" ....  Great work thanks
bforonda
Frequent Visitor
Frequent Visitor
Aloha @Joe Clarke,
Switch Information: Cisco 9200L, 17.12.4
Update: Other's have mentioned similar error since upgrading to either 17.9.6 or 17.12.4. I did downgrade to 17.9.5 on a test switch and the error went away.
Do you happen to know what might be triggering the error below? From my troubleshooting, it seems the SL script isn't removing the port after it's been reconnected. In this case, the port is GigabitEthernet1/0/5.
Any idea why it might be unable to read arr_einfo(msg)? For testing purposes, I'm manually flapping the ports to trigger the event.
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: can't read "arr_einfo(msg)": no such element in array
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: while executing
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: "regexp {Interface ([^,]+), changed state to up} $arr_einfo(msg) -> iface"
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: invoked from within
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: "$slave eval $Contents"
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: (procedure "eval_script" line 7)
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: "eval_script slave $scriptname"
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: "if {$security_level == 1} { #untrusted script
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: interp create -safe slave
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: interp share {} stdin slave
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: interp share {} stdout slave
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: ..."
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: (file "tmpsys:/lib/tcl/base.tcl" line 50)
Apr 11 2025 14:31:39.924 HST: %HA_EM-6-LOG: sl_suspend_ports.tcl: Tcl policy execute failed:
9 98 Actv success Fri Apr11 14:31:39 2025 syslog script: sl_suspend_ports.tcl
10 99 Actv success Fri Apr11 14:32:08 2025 syslog script: sl_suspend_ports.tcl
more flash:susp_ports.dat
GigabitEthernet1/0/12 1717844400 GigabitEthernet1/1/2 1717585200 GigabitEthernet1/0/3 1717585200 GigabitEthernet1/1/3 1717585200 GigabitEthernet1/0/4 1717585200 GigabitEthernet1/0/5 1739012400 GigabitEthernet1/1/4 1717585200 GigabitEthernet1/0/14 1717585200 GigabitEthernet1/0/16 1717585200 GigabitEthernet1/0/17 1717585200 GigabitEthernet1/0/9 1744369200 GigabitEthernet1/0/18 1717585200 GigabitEthernet1/0/19 1717585200 GigabitEthernet1/0/20 1717585200 GigabitEthernet1/0/21 1717585200 GigabitEthernet1/0/22 1717585200 GigabitEthernet1/0/23 1717585200 GigabitEthernet1/0/24 1717585200 GigabitEthernet1/0/10 171758520
