guruprasadr
Level 11
Level 11
System Software Conversion Procedure from CatOS to Cisco IOS for Cisco Catalyst 6500 Series Switches
This document explains how to convert the system software on Cisco Catalyst 6500 series switches from Catalyst OS (CatOS) on the Supervisor Engine with Cisco IOS Software on the Multilayer Switch Feature Card (MSFC) to Cisco IOS on both the Supervisor Engine and MSFC.
Thanks & Regards,
Guru Prasad R
Janel Kratky
Thanks for posting the CatOS to Cisco IOS conversion procedure for the Catalyst 6500. There are other communities where your document could get more visibility because the discussions are focused on a specific technology or product. You might consider posting this document in Documents tab of one of the Network Infrastructure subcommunities.
Janel Kratky
guruprasadr
Level 11
Level 11
Thanks Janel for the directions. I have moved the document under:
Network Infrastructure > LAN, Switching and Routing.
Best Regards,
Guru Prasad R
