Cisco NFVIS TACACS authentication timeout configuration
karunanithi
All,
I am looking for documentation or steps to modify the default TACACS timeout configuration, as we are implementing the MFA (Mutli Factor Authentication) for authentication it is getting a timeout. I believe the default timeout is 5 Sec. We would need to increase to 30 Sec. However I am unable to see commands change the setting and I cannot find any documentation on this topic. I have referred to the below one.
https://content.cisco.com/chapter.sjs?uri=%2Fsearchable%2Fchapter%2Fcontent%2Fen%2Fus%2Ftd%2Fdocs%2Frouters%2Fnfvis%2Fconfig%2F3-9-1%2Fnfvis-config-guide-3-9-1%2Fnfvis-config-guide-3-6-1_chapter_010001.html.xml&platform=Cisco%20Enterprise%20NFV%20Inf...
Kindly help
karunanithi
team, any help ?
dot1x timeout supp-timeout <<- I think this timeout you looking for
Thanks for your reply. @MHM Cisco World .  I think the above command is on the interface level.  I am trying to configure the management interface for TACACS logins and it's timeout. Is there a global command to set the tacacs timeout ?
Thanks in advance.
