Martin95
I struggled to find a suitable contact option for this minor error, so if this is the incorrect place for resolving the issue, I hope I can be pointed towards a more suitable space.
As stated in the title
There is a minor error on the NetAcad: Cybersecurity Essentials: Module 6.2.1.5 - Risk Analysis
The two examples describe the difference between Quantitative Risk Analysis and Qualitative Risk Analysis in this order, the two figures attempt to visualise these examples and their differences explained in correspondence with the text.
I have noticed that both figures have the same heading that reads "Quantitative Example" for both figure; 1 and 2.
Please rectify the figure 2 title, from "Quantitative Example" and change it to "Qualitative Example"Quantitative analysis.jpg
I have attached two snippets of these pages, should my description be inefficient.
Thanks in advance
Martin
NotEnoughTime
This should probably be posted in:
https://community.cisco.com/t5/networking-academy/ct-p/netacad
You can also ask your Academy Support Center to submit a trouble ticket regarding the curriculum as well.
