DCHP failed. APIPA is being used problem in packet tracer
mbgfj
Hi, i already saw the same question from someone, but nothing from there helped me.
I have 2 switches and one server (i had another but turned it off) , laptops that are connected to second switch can receive addresses with dchp, but pc`s that are connected to second switch can not. i needed to set trusted ports and i did, but it just doesn`t work...
I attached my file, its pc0, pc1 and pc2 problem, i hope someone can help me...
@mbgfj
 you need add the trust command on the interface that goes from one switch to the other and you need to add the command on the interfaces that the PC is connected.
Take a look on the file attached.
@mbgfj
omg thanks a lot!!
