DHCP failed. APIPA is being used - Project
mhollstein4
I'm working on an assignment in packet tracer and when go into any of my devices and switch from static to DHCP it shows a message stating "DHCP failed. APIPA is being used."
The questions I am needing to answer via a screenshot are below:
*Confirm that both PCs and IP address’ are on the DHCP Server.
Provide 1 screenshot of one of the PCs
*Confirm both Laptops obtain IP configuration from DHCP Server
Provide 1 screenshot for one of the Laptop1
(I have some other questions needing to be answered but if I can have some advice at what is/isn't entered correctly I can hopefully complete the rest without an issue)
Thank you
(I have attached the zip file)
@mhollstein4
 You were missing the DHCP server configuration on the topology. Take a look on the file attached.
