Using OSPFv3 in Packet Tracer
spj2019
Hope I wound up in the right forum..... I'm trying to use OSPFv3 on packet tracer but the IOS won't accept the ospfv3 keyword when I try to define the router (router ospfv3 xx). The OSPFv3 keyword is not in the Help section - I'm using Packet Tracer version 7.2.1.0218 downloaded about a month ago.
I would appreciate any pointers ! Thanks
Jaderson Pessoa
@spj2019 hello,
try it;
rt(config)#ipv6 unicast-routing
rt(config)#ipv6 router ospf 1
and start your ospfv3 configuration..
Jaderson Pessoa
*** Rate All Helpful Responses ***
7 Replies 7
Jaderson Pessoa
@spj2019 hello,
try it;
Jaderson Pessoa
Thank you ! Would this be the 'traditional mode' commands for OSPFv3 ? On our switch you can use the OSFPv3 syntax... I was trying with that.
This is traditional mode for use OSPFv3 in packet trace :)
Jaderson Pessoa
Hi, thanks for your reply. It works now, I was trying to use the other Ospfv3 syntax. Is this the 'traditional mode' of Ospf commands?
yes it is.
Jaderson Pessoa
As I am not getting routes published in my routing tables by ipv6 OSPF, I found this at the Cisco site :
Open Shortest Path First Version 3 (OSPFv3) is a link state routing protocol. Unlike OSPFv2, which supports IPv4, the original implementation of OSPFv3 supports IPv6 (unicast only). With the introduction of OSPFv3 support for address families (AFs), OSPFv3 now can support IPv4 unicast address families.
Does it mean I have a limitation in Packet tracer ?
@spj2019 hello,
to show ipv6 route, try using command below;
show ipv6 route
Packet tracer is limmited to something, if you need feature more advanced, i suggest you to use,  GNS3 or EVE-NG.
Jaderson Pessoa
