Badauth for no reason.
sulabhshrestha
I'm getting "badauth". But username and password hasn't been asked, and show "badauth" directly. What's the reason? Link I had used -> https://updates.opendns.com/nic/update?hostname=Home
20 Replies 20
reham1
What is the ddclient that you are using when you receive this error.
Is it DNS-O-Matic or something else.
In addition, there are a few characters that cannot be used in passwords used in the Dynamic IP Updater Client. These characters include:***^, &, , ~, `,*** and ***%***. Please change your OpenDNS account password so you don't include any of non-alphanumeric characters: https://dashboard.opendns.com/myaccount/password
In addition, please also check to make sure that the system time and time zone are correct on your computer.
cedjo
when you change your password you are requested to provide a password with non-alphanumeric characters...
I have also a badauth since 1 day from synology NAS, postman request, manual tests or ddclient.
I have changed password but nothing is working.
openme12
Same here. Changed nothing on my end, and now overnight get bad authentication on both Synology NAS and Asus router all of a sudden.
My original password had one special character (a dot), tried to change it to one just alfanumeric, but OpenDNS needs a special character in password, so put in a dash. Stil getting the error.
flash13
I'm having the same behavior, seems something with their authentication system.  I saw the behavior with my (legacy) Synology DDNS alerting starting yesterday.  I have tried updating via a couple of dnsomatic containers in Docker and using the DirectUpdate application.  Each one returns "badauth" when it is the same credentials I have used for a couple of years and successfully logged into this forum with.
Hate to say it, but it's you (opendns/dnsomatic), not me.  At least this time.
reham1
In general, if DNS-O-Matic is handing back a `badauth` error, this means that the username and/or password that are being passed to its API are incorrect.
There are a few characters that cannot be used in passwords used in the Dynamic IP Updater Client. These characters include:***^, &, , ~, `,*** and ***%***. Please change your OpenDNS account password so you don't include any of non-alphanumeric characters: https://dashboard.opendns.com/myaccount/password
Please try using this link to reset your password https://www.dnsomatic.com/account/
In addition
If this does not help please try the following URL:
https://updates.dnsomatic.com/nic/update?hostname=Home
stephanvs
Same here with a mikrotik router. When accessing the link from Edge, it asks for username (email) and password (update-only password), but then nothing happens, it asks again and again...
cedjo
I did reset my password, with only $ in it, same problem.
still not working
reham1
If the steps above do not resolve the problem I would suggest that you create a support request so we can further troubleshoot the problem
cedjo
Hi Reg,
this is already done:
ticket number is [892687]
https://support.opendns.com/hc/requests/892687
anstelioss
Same issue here.
Changed nothing and getting badauth from https://updates.opendns.com/nic/update? on my Synology NAS since 4-5 days ago.
nesdns
4728470388 I have this issue too, it started yesterday.
Prior to this my Synology router was updating my DNS-o-Matic account without issue. I've a custom DDNS update in DSM 7's Control Panel (Synology NAS) that was a fallback for if the router was replaced, this custom DDNS was working but now isn't too.
Also, on Mac, dDNS Broker cannot access DNS-o-Matic not OpenDNS accounts to update them. Plus using Mac's Terminal and 'curl' with a correctly crafted URL (with username/password, using HTML character code %40 for @) doesn't work, nor does using Safari with the correctly crafted URL (without username/password): where the authentication just repeats itself.
Using 'curl' returns 'badauth' yet I can log into DNS-o-Matic and OpenDNS web sites, as evidenced by being able to post here.
I've tried updating my account password and that had no effect.
I've raised a support ticket (#893086) and referenced this community thread.
robertot
Same issue here, I noticed it today.
I tried using "ddclient" instead of "inadyn" (under Debian Linux) but the result did not change.
Opened support ticket #893303.
vagabondb
I started having the same issue with curl command in my update script. I noticed the issue firstly appeared on the 7th of December. Before then everything worked well. At least what can I see from logs
robertot
It works again.
