Browsing Issues
support42
Community Member
anyone else experiencing random browsing issues with opendns for the last 2 days. I am a partner re seller and even I cannot get effective support. I think I will be changing to Webroot DNS for better support options. Open DNS is no longer the only game in town. This is affecting hundreds of my clients endpoints. I have tried resetting everything in the open dns portal to defaults and yet sites like amazon.com are randomly blocked with an umbrella certificate error and others like yankees.com or raise.com the content on the site is partially blocked. Just curious if anyone else is experiencing this?
rotblitz
Level 7
Level 7
No, I do not face such kind of problems.
"yet sites like amazon.com are randomly blocked with an umbrella certificate error"
About this specific symptom see https://support.opendns.com/hc/en-us/articles/227988787
According to your symptoms it looks like domains being used by these sites are being blocked by a dashboard policy.  You need to modify the policy to not block them.
yankees.com: https://www.webpagetest.org/result/180628_28_9845e83878e0cc7d1cb90d02c9a1c44c/1/domains/
raise.com: https://www.webpagetest.org/result/180628_FF_e2c8f7803f9882aa0bb638734758b900/1/domains/
amazon.com: https://www.webpagetest.org/result/180628_3P_d12c618a5290856643b3212642b65dfa/1/domains/
"I have tried resetting everything in the open dns portal"
Yep, this may well be the reason for these issues.
 "I think I will be changing to Webroot DNS for better support options."
What Umbrella support option did you chose from?  Basic, Gold, Platinum?
https://umbrella.cisco.com/support/options/
Probably not the right one?  Or none at all?
micolema
This forum is for Home/Free users of OpenDNS. If you are a MSP, please email Support at [email protected]. I see you submitted a ticket yesterday, which has since been answered by our support agents.
