02-05-2017 03:10 AM
Hi!
I bought F-Secure Freedom and tried it yesterday. I can´t get it to connect to internet.
I have OpenDNS in my modem/router. OpenDNS Updater on the computer. Also OpenDNS Crypt, but that one should not be active on my laptop on which I tried Freedom.
I run Avast Premier on the computer.
I tried to run Avast SecureLine and that worked perfectly.
Any suggestions to what could be the problem?
02-05-2017 12:42 PM
Problem solved!
02-06-2017 06:14 AM
You had to disable Avast's Secure DNS, right?
02-06-2017 07:00 AM
I took the OpenDNS settings from my modem/router.
After that F-Secure Freedome works perfectly.
On the computer I left OpenDNS Crypt and OpenDNS Updater and it connects via them as soon as I close Freedome.
The strange thing was that Avast SecureLine worked with the OpenDNS setting in the modem/router.
So Avast SecureLine would had been the better alternative, but I got such a good deal for the Freedome, that I got that.
I let Avast Premier be as it was...
