10-21-2025 07:54 AM
Hello OpenDNS Community,
We are encountering a problem where reverse DNS (PTR) lookups for one of our IP addresses succeed on most DNS servers but consistently fail when using OpenDNS resolvers. Specifically, the PTR record resolves correctly on standard DNS servers but returns an NXDOMAIN error when queried through OpenDNS.
We have confirmed that the PTR and corresponding A records are correctly configured and fully consistent.
Has anyone experienced similar issues or could offer insight into why OpenDNS resolvers might fail to resolve certain reverse DNS entries even though they appear properly set up?
Thanks in advance for any guidance or suggestions.
Best Regards
10-22-2025 05:21 PM
Try refreshing the cache on your domain at (cachecheck.opendns.com).
10-23-2025 12:32 AM
Hi Reham
I have refreshed the domain in cachecheck.opendns.com. But the problem is the same:
In opendns:
PS C:\Users\rriera> nslookup.exe 62.37.182.181 208.67.222.222
Servidor: dns.sse.cisco.com
Address: 208.67.222.222
*** dns.sse.cisco.com no encuentra 62.37.182.181: Non-existent domain
In google dns
PS C:\Users\rriera> nslookup.exe 62.37.182.181 8.8.8.8
Servidor: dns.google
Address: 8.8.8.8
Nombre: mail6.divinaseguros.com
Address: 62.37.182.181
Thanks in advance for your answer
10-23-2025 04:19 PM
Please specify the exact domain address you are having this problem with.
Your reply is appreciated
10-23-2025 06:27 PM
I went to the dashboard https://dashboard.opendns.com/ and "Never Blocked" divinaseguros.com in order for it to come up on my OpenDNS PC.
Apologies in advance for Google Translate:
Fui al panel de control https://dashboard.opendns.com/ y aparecía "Nunca bloqueado" divinaseguros.com para que apareciera en mi PC con OpenDNS.
10-23-2025 06:41 PM
The results of a dig test (excerpt shown below) on the domain show that whether a DNS resolver is not used or when Google and OpenDNS are used the IP address returned is 40.122.36.65
; <<>> DiG 9.10.6 <<>> divinaseguros.com
divinaseguros.com. 0 IN A 40.122.36.65
; <<>> DiG 9.10.6 <<>> divinaseguros.com @8.8.8.8
divinaseguros.com. 5 IN A 40.122.36.65
; <<>> DiG 9.10.6 <<>> divinaseguros.com @208.67.222.222
; <<>> DiG 9.10.6 <<>> divinaseguros.com @208.67.220.220;
10-23-2025 08:03 PM - edited 10-23-2025 08:13 PM
Per cachecheck.opendns.com for divinaseguros.com
South America, North America, Europe, Australia, Asia and Africa all point to 40.122.36.65 (Organization: Microsoft Corporation (MSFT))
If you manage this domain, contact your DNS host and report the problem.
https://dnschecker.org/#A/divinaseguros.com says the same as the Cachecheck above.(40.122.36.65)
I concur with your findings using DiG 9.16.23-RH from Oracle Linux on WSL.
https://www.whois.com/whois/62.37.182.181
https://www.whois.com/whois/divinaseguros.com
I concur with the following:
PS C:\Users\ZZ> nslookup.exe 62.37.182.181 8.8.8.8
Server: dns.google
Address: 8.8.8.8
PS C:\Users\ZZ> nslookup.exe 62.37.182.181 208.67.222.222
Server: dns.sse.cisco.com
*** dns.sse.cisco.com can't find 62.37.182.181: Non-existent domain
10-24-2025 12:20 AM
Hi Bryan and Reham. Thanks for your responses.
But I don't understand what the problem is with that the domain register for divinaseguros.com which is 40.122.36.65 (azure) and the register for mail6.divinaseguros.com is 62.37.182.181.
We have open a case with the internet provider for reverse domain for the ip 62.37.182.181 and it is ok.
Yes, the problem that we have is that:
Server: dns.google
Address: 8.8.8.8
And we have problem with email servers that use openDNS , because they can´t resolve de reverse register.
Thanks for your time.
10-24-2025 09:55 PM
Rafael,
    Have you tried this site?  https://mxtoolbox.com/emailhealth/divinaseguros.com/
Bryan
10-28-2025 12:44 AM
Thanks Bryan.
I have seen the error for DNS: Primary Name Server Not Listed At Parent
I'm going try to resolve that issue, and will test OpenDns again.
