01-27-2015 10:58 AM
I have reviewed the documentation and I am sill unable to get web sites blocked. My dashboard shows IP address 97.121.160.114, but my updater box shows IP address 198.105.244.23. I am sure i have a dynamic IP address which is why i have downloaded the updater. The DNS O Matic box is unchecked. Open DNS has worked for me for about a year and i recently discovered the web site protection is no longer functional. It seems to be a dynamic IP address issue, but i cannot figure out how to solve the problem. Thank you.
07-01-2016 10:29 AM
"I don't think that's a OpenDNS IP."
Don't think, but measure. Your thought is wrong.
nslookup 146.112.61.104
Server: dns1.lcoal.prv
Address: 10.165.161.13
Address: 146.112.61.104
That shown, www.youtube.com is indeed blocked for you by OpenDNS, by your "always block" list.
"From what I can tell, for every device, my Router is the DNS lookup. I want this to be the case anyway."
Not sure if I understand. What is "this"?
"If I search for youtube on google and click one of the resulting links, I can still access Youtube."
Is this on a smart device? If so, then this smart device ignores or circumvents your settings in some way, e.g. by using Google's proxy (cache) service, or your settings are wrong. Visit http://welcome.opendns.com/ on this smart device to see if you're using OpenDNS at all on it. If not, you cannot expect your filtering settings taking effect as long as you don't use OpenDNS.
07-01-2016 11:52 AM
Ok So OpenDNS is indeed blocking the site when On a PC. Especially where welcome page has confirmed that I am using openDNS.So this takes care of the main problem. I understand your point about smart devices using Google Proxy or IP Access.
Another issue, bit less critical, On the PC, where OpenDNS is confirmed to have blocked, now instead of the Blocking Page I expect to get (like for internetbadguys ), I get "Unable to connect" page. However, if I go into my settings and switch to default block page instead of custom message, then I get standard block page. https://block.opendns.com/?url=9080868586677015688078&server=chi15&prefs=&tagging=&nref is the URL in question when I get Unable to connect.
As to smart devices, welcome page confirmed that I am using OpenDNS. Accessing straight up youtube.com via browser gives me the same error/message as above. Youtube app is using something else to circumvent my connection and that has nothing to do with OpenDNS as you said.
07-01-2016 12:43 PM
"Especially where welcome page has confirmed..." should read "Only in case where welcome page has confirmed...".
"I get "Unable to connect" page. However, if I go into my settings and switch to default block page instead of custom message, then I get standard block page."
I visited that long URL you provided, and I get the normal OpenDNS block page. As a proof, your customized message for youtube.com is "Access to this page was blocked because it may contain security threats".
I would assume your browser or something specific to your environment is causing to get "Unable to connect". You had to run a network or browser trace to see what's going on. But no worries, the domain is blocked either way, as you want.
"Accessing straight up youtube.com via browser gives me the same error/message as above."
Yes, this is what I would have expected, because you must use DNS for name resolution in this case, so OpenDNS can do its job.
"Youtube app is using something else to circumvent my connection and that has nothing to do with OpenDNS as you said."
Correct. This is what I have experienced with the smart devices in my household too. I have a special sophisticated AVM router where I can block and report entering IP addresses for web access (i.e. cases were DNS is not being used), and I collected hundreds of those IP addresses in between, short time after the smart devices connected via WLAN. These addresses were often registered to Google (which is the owner of YouTube), but also to other companies offering smart device apps for Android and iOS. The only way to block this is to use a router supporting blocking this as mine, or to block the related IP address ranges outgoing if supported by the router, also as mine.
07-01-2016 02:42 PM
My custom Message is set to
"There are problems accessing content on the website. Please check back again later."
not the one you mentioned. But if you're saying that link resolves to OpenDNS page, then could it be that openDNS depends on certain browsers for this url to work ? Anyway that's academic excercise anyway, since core purpose of blocking the website is served and I need to find alternate ways to block the app.
07-02-2016 04:45 AM
"could it be that openDNS depends on certain browsers for this url to work ?"
Certainly. This is the case with nearly all web pages in the world. It's the browser interpreting them.
08-12-2016 09:56 AM
Like everyone else I'm having the same issue. I'm using a Mac so I'm not sure how to post the txt file that you are needing. I get the oops page as well. My ISP match up, DHCP is disabled and IPv6 is disabled. I've reset the router, cleared my cp cache along with OpenDNS cache. Please help
08-12-2016 10:07 AM
I can't edit my account so I'm posting some screen shots that are confusing me about my IP. Which one is it?
08-12-2016 10:46 AM
@Crytical
The one 72.174.21.60 looks like ISP issued address. From screen 1 seems like the OpenDNS is perhaps not updated with this IP. The 3rd screen is confusing. It makes it seem like OpenDNS is updated.
What do you see when you try the blocked site ?
08-12-2016 10:56 AM
Checking the blocked site I get this. "InternetBadGuys.com is only a demonstration site." Grrrr.....
I updated my ISP using the OpenDNS updater.
08-12-2016 11:13 AM
Oops, this thread is very full and started one and a half year ago. It would have been better you opened a thread on your own... :(
What does "My ISP match up" mean, and why and where did you disable DHCP? Was the latter part of any instruction to use OpenDNS?
Also what is a "cp cache", and what is the "OpenDNS cache"? All these sound suspect...
And what does "I can't edit my account" mean? Why would you need to edit your account? What account?
Well, checking your screen shots, it seems you're facing a so called "IP address mismatch", i.e. your ISP does funny things and routes your DNS traffic differently from your web traffic, so the internet will see two different IP addresses from you. In this case it's hard to use OpenDNS with its enhanced features unless your ISP can change the behavior.
In order to see more, copy & paste the complete plain text output of the following diagnostic commands here, taken from your Mac's terminal window:
nslookup -type=txt debug.opendns.com.
nslookup -type=txt debug.opendns.com. 208.67.220.220
nslookup whoami.akamai.net.
Also, what IP address does http://myip.dnsomatic.com/ return?
08-12-2016 11:15 AM
"I updated my ISP using the OpenDNS updater." - This is impossible, no way!
08-12-2016 11:34 AM
I didn't want to start a new thread as some forums despise that.
My ISP match up. I meant that my IP addresses match up from my OpenDNS home page and asking Google what my IP address is. 72.174.21.60
Disable DHCP I was having constant wireless internet drops from my router. Once I disabled DHCP in my router the problem seemed to have been fixed as I no longer have drops in my internet connection.
Use OpenDNS I only want to block a few websites so the children can't access....
CP Cache More specifically, web browser cache, OpenDNS cache can be found under advanced settings. It was mentioned in another thread to try this route if the websites weren't being blocked.
Can't edit my account I meant post.
Server: 192.168.0.1
Address: 192.168.0.1#53
** server can't find debug.opendns.com.: NXDOMAIN
Server: 208.67.220.220
Address: 208.67.220.220#53
Non-authoritative answer:
debug.opendns.com text = "server 11.dfw"
debug.opendns.com text = "flags 20 0 8050 1950000370000010020"
debug.opendns.com text = "originid 52846173"
debug.opendns.com text = "actype 2"
debug.opendns.com text = "bundle 8980461"
debug.opendns.com text = "source 72.174.21.60:64286"
Authoritative answers can be found from:
Server: 192.168.0.1
Address: 69.144.127.38
myip.dnsomatic.com = 72.174.21.60
Hope all this helps.
08-12-2016 12:00 PM
It does help!
It's really hard to understand you if you use different and own terms, like "ISP" instead of "IP", "my OpenDNS home page" instead of whatever, "CP cache" instead of browser cache, "edit" instead of "post", etc... :(
"Disable DHCP I was having constant wireless internet drops from my router."
This item is then totally unrelated to OpenDNS and its use. You shouldn't have it mentioned here.
"More specifically, web browser cache"
Beside the browser cache, don't forget to flush the DNS resolver cache too: https://support.opendns.com/entries/26336865
"OpenDNS cache can be found under advanced settings" - Where are these "advanced settings"? At the OpenDNS dashboard or on the computer?
Is it this? http://cachecheck.opendns.com/ - Well you cannot solve any of your listed problems with this tool.
Now to your outputs:...
Currently your DNS queries go to Charter's DNS service, not to OpenDNS, therefore your OpenDNS settings cannot take effect. This looks as if you had not configured the OpenDNS resolver addresses 208.67.2**.*** on the router at 192.168.0.1 or on your computer, or this configuration doesn't take effect but is successfully ignored. Review this part of configuration or post a screen shot of where these addresses are configured.
The good news, if your DNS queries would be sent to OpenDNS, everything would work perfectly. There is no IP address mismatch, and your IP address is 72.174.21.60 for both, DNS and web traffic, and your OpenDNS dashboard is correctly updated with it.
08-12-2016 12:58 PM
"This looks as if you had not configured the OpenDNS resolver addresses 208.67.2**.*** on the router at 192.168.0.1"
I was able to solve the issue by entering:
into the DNS server.
Everything works great now thanks for being patient and helping out.
08-12-2016 01:02 PM
Well, if you followed the instructions provided for setting up OpenDNS, this is the first step. Not sure why you did it differently, starting with something else...
