OpenDNS suddenly not filtering
cavecanem90
I haven't (knowingly) changed any settings. Nevertheless, OpenDNS suddenly stopped filtering. It is set up on my router, so I unplugged and reset the modem and router. That seems to have fixed the problem on the one PC that is directly connected to the router by Ethernet cable. However, OpenDNS is not filtering for any device that accesses the internet through the router by WiFi, even after I flush the DNS cache through those devices.
Any help would be greatly appreciated.
Here is diagnostic info (run from the PC that is connected directly to the router by Ethernet):
PS C:\WINDOWS\system32> nslookup -type=txt debug.opendns.com. 208.67.220.220
Server:  resolver2.opendns.com
Address:  208.67.220.220
Non-authoritative answer:
debug.opendns.com       text = "server m29.dfw"
debug.opendns.com       text = "flags 20 0 50 39504007E00400014C0"
debug.opendns.com       text = "originid 47222265"
debug.opendns.com       text = "actype 2"
debug.opendns.com       text = "bundle 8729901"
debug.opendns.com       text = "source 75.140.245.181:50930"
PS C:\WINDOWS\system32> nslookup -type=txt which.opendns.com.
1.0.168.192.in-addr.arpa
        primary name server = localhost
        responsible mail addr = nobody.invalid
        serial  = 1
        refresh = 600 (10 mins)
        retry   = 1200 (20 mins)
        expire  = 604800 (7 days)
        default TTL = 10800 (3 hours)
Server:  UnKnown
Address:  192.168.0.1
which.opendns.com       text = "m45.dfw"
PS C:\WINDOWS\system32> nslookup whoami.akamai.net
        serial  = 1
Server:  UnKnown
Addresses:  2620:0:cc6::167
          204.194.238.167
PS C:\WINDOWS\system32> nslookup www.internetbadguys.com
        serial  = 1
Server:  UnKnown
Addresses:  146.112.61.108
          146.112.61.108
Here is the same information run from a WiFi-connected laptop:
C:\WINDOWS\system32>nslookup -type=txt debug.opendns.com. 208.67.220.220
debug.opendns.com       text = "server m49.dfw"
debug.opendns.com       text = "source 75.140.245.181:51806"
C:\WINDOWS\system32>nslookup -type=text which.opendns.com
unknown query type: text
Server:  rns01.charter.com
Address:  2607:f428:ffff:ffff::1
C:\WINDOWS\system32>nslookup whoami.akamai.net
Address:  68.114.44.107
C:\WINDOWS\system32>nslookup www.internetbadguys.com
Address:  67.215.92.210
rotblitz
Level 6
Level 6
Well, you must use OpenDNS, not Charter's DNSv6 service:
You do not expect Charter to do OpenDNS' job for you?
Also, you should write commands very accurately (txt, not text).
For a very recent solution see e.g. https://support.opendns.com/hc/en-us/community/posts/115020389183
