Site Inaccessable while using OpenDNS
jdsmith14
Community Member
I am trying to access this site while using OpenDNS:
https//intranet.quintiles.com
Even when setting blocking to "None" the site remains inaccessible.
When reverting to non OpenDNS DNS servers, the site is accessible.
Any suggestions would be appreciated!
5 Replies 5
rotblitz
Level 7
Level 7
Did you mean https://intranet.quintiles.com/ ?
I cannot reproduce your problem.
Copy & paste the complete plain text output of the following diagnostic commands here when OpenDNS is being used:
nslookup -type=txt debug.opendns.com.
nslookup intranet.quintiles.com.
jdsmith14
Community Member
Correct on: "Did you mean https://intranet.quintiles.com/ ?"
Here is the output as requested:
Server: resolver1.opendns.com
Address: 208.67.222.222
Non-authoritative answer:
debug.opendns.com text =
"server m11.jnb"
"flags 20 0 8050 19500007E00400014C3"
"originid 58234042"
"actype 2"
"bundle 9188782"
"source 154.69.230.156:60924"
_______________________________________
DNS request timed out.
timeout was 2 seconds.
*** resolver1.opendns.com can't find intranet.quintiles.com.: Server failed
Thank you for the assistance!
rotblitz
Level 7
Level 7
I see now.  The tool https://cachecheck.opendns.com/ returns SERVFAIL responses for some OpenDNS locations although I have refreshed the cache.  Diving deeper, I can see that intranet.quintiles.com is an alias of the real name connect.gss.quintiles.com which has no A or AAAA record associated at their nameservers ns.rackspace.com and ns2.rackspace.com.  Also, gss.quintiles.com has additional nameservers of usadc-ngsse11.quintiles.com and ieedc-ngsse11.quintiles.com which do not respond at all.
That said, the problem is with the authoritative DNS configuration of quintiles.com.  You have to contact them to get it corrected.
You can help yourself as a temporary workaround while adding this entry to your local hosts file:
65.205.190.227 connect.gss.quintiles.com connect.quintiles.com intranet.quintiles.com
If this entry doesn't work, try the same with 62.17.37.134 and  65.205.190.117.
jdsmith14
Community Member
Thank you for the feedback and clarification - The problem turned out to be with the ISP's DNS servers, with several international sites not being available.
Again thank you for the detailed assistance.
rotblitz
Level 7
Level 7
"The problem turned out to be with the ISP's DNS servers"
If you're using your ISP's DNS service, not OpenDNS, then your thread has not to appear in this forum.  If you used OpenDNS, then your ISP's DNS service is out of scope, and vice versa.
