Sky Q hub problems
Anonymous
Not applicable
Hello
I cannot for the life of me change the Dynamic dns address on the Sky router. I am not particularly literate in IT, but need this to monitor the children’s activity’s- could anyone point me in the right direction please, on how to get OpenDNS working with a Sky hub?
Thank you
rotblitz
Level 6
Level 6
Note, DNS server addresses are not dynamic...
What you're saying, does this mean there are no fields to enter DNS server addresses?  Then you cannot configure OpenDNS on the router, but you still can try to configure it on the end user devices.
If you want to configure OpenDNS on the router, then get another router or connect a second router to the Sky hub device.
Anonymous
Not applicable
Thank you for your reply. No it would seem I’m not able to change the dns, may I then ask what is a suitable router to buy, and is there a step by step installation for a middle aged Mum with little IT capabilities? I am in the UK.
many thanks
rotblitz
Level 6
Level 6
