Using OpenDNS ? No
tamas.pocs55
Community Member
 Hey
I have some trouble with configurating the DNS on my router.
I did all the same as in the tutorial and I think nothing works for me.
I will send you a picture of my confugurations. The test always say that I'm not using OpenDNS yet.
What can be the problem ?
Thanks for Your help.support.opendns.com_hc_user_images_SJe1E-l9o6FXy5hIBXzgkQ.png
7 Replies 7
rle78675
Community Member
uncheck or disable dhcp relay. Did you reset your modem? do a hard reset that's usually done by pressing a button at your modem/router for a period of time, then after that open command prompt "cmd" then type "ipconfig /release" then type "ipconfig /renew" then "ipconfig /flushdns" don't add the "
I hope you get it.
tamas.pocs55
Community Member
Okay I understood. If i hard reset my modem, isn't it going to loose all the settings ? I mean i will have to reconfigure the rooter, won't I ?
rotblitz
Level 7
Level 7
Don't hard reset your router for now.  It may not be due to your router.
I see that you configured OpenDNS on the router and on the computer.  Why this?  Configuring on the router should be sufficient.
Copy & paste the complete plain text outputs of the following diagnostic commands to here:
nslookup -type=txt debug.opendns.com. 208.67.220.220
nslookup -type=txt which.opendns.com.
nslookup whoami.akamai.net.
tamas.pocs55
Community Member
I don't know what is happening. Once it says I use OpenDNS and all is functioning, but once it says I DO NOT use OpenDNS and nothing works... It switches from a minute to another.
I tried to copy & pase lines above.
Maybe there is something wrong with the IP configurations ?
rotblitz
Level 7
Level 7
Who can tell without seeing the command outputs?
In addition I would need to see the output of:
netsh interface ipv4 show config   (for Windows)
ifconfig -all (for Linux and OS X)
semillacuern
Community Member
I have same problem. My command outputs is there: please help @rotblitz
Servidor: resolver2.opendns.com
Address: 208.67.220.220
Respuesta no autoritativa:
debug.opendns.com text =
"server m75.lax"
"originid 500265662"
"actype 2"
"bundle 13010812"
"source 189.189.44.31:63514"
Servidor: 2806-1040-ffff-0003-0000-0000-0000-000e.ipv6.infinitum.net.mx
Address: 2806:1040:ffff:3::e
which.opendns.com text =
"I am not an OpenDNS resolver."
Nombre: whoami.akamai.net
Address: 187.141.30.235
thanks
rotblitz
Level 7
Level 7
You’re using your ISP’s DNSv6 service instead of OpenDNS. Configure IPv6 with ::ffff:d043:dedc and ::ffff:d043:dcde
