01-11-2021 04:41 PM
I've searched for this nuance but can't seem to find it. So apologize in advance if this is obvious. Works great on Chrome. On same machine go to I.E. and nothing gets blocked. DNS flushed. Browser caches cleared.
01-12-2021 02:00 AM
Visit dnsleaktest.com with IE to see what DNS service you're actually using. There may be a plugin or add-on making its own DNS thing.
01-12-2021 07:56 AM
rotblitz, thank you. So, I did that. 5 servers found. 3 are OpenDNS. 2 are my ISP. Not sure what that means or what to do now. I am not using a VPN.
01-12-2021 12:08 PM
You must get rid of your ISP‘s addresses. As I said, it may be an add-on for IE or so. I cannot know. Especially, this is not OpenDNS specific but would be a problem for any DNS service you would want to use.
01-12-2021 02:09 PM
rotblitz... thanks again. so I disabled everything... flushed dns, rebooted all that.... now only my isp address shows with dnsleaktest.com... edge is doing the same thing. works great with chrome but I'm stuck blocking ie and edge. weird...
Name Adobe Acrobat Create PDF from Selection
Publisher Adobe Systems, Incorporated
Status Disabled
Architecture 32-bit and 64-bit
Name Adobe Acrobat Create PDF Helper
Status Disabled
Name Adobe Acrobat Create PDF Toolbar
Status Disabled
Name Adobe PDF Reader
Publisher Adobe Inc.
Status Disabled
Name IEToEdge BHO
Publisher Microsoft Corporation
Status Disabled
Load time 0.01 s
Navigation time 0.00 s
Name Lync Click to Call
Status Disabled
Architecture 32-bit
Name McAfee WebAdvisor
Publisher Not Available
Status Disabled
Publisher McAfee, LLC
Status Disabled
Name Microsoft Shell UI Helper
Status Disabled
Name OneNote Linked Notes
Status Disabled
Architecture 32-bit
Name Scripting.Dictionary
Status Disabled
Name Send to OneNote
Status Disabled
Architecture 32-bit
Name Shockwave Flash Object
Status Disabled
Name Skype for Business Browser Helper
Status Disabled
Architecture 32-bit
Name Tabular Data Control
Status Disabled
Name Windows Media Player
Status Disabled
Name XML DOM Document
Status Disabled
Name XML DOM Document 6.0
Publisher Microsoft Windows
Status Disabled
01-12-2021 02:13 PM
No idea. Anybody else?
