01-30-2019 09:59 AM
According to my knowledge from https://tmgmatrix.cisco.com
Cisco WS-C3850-24XS-E switch supports SPF GLC-TE running at 1000 Mbps and 100 Mbps
Is this correct.
Solved! Go to Solution.
01-30-2019 11:41 AM
Yes, it is correct!
Here is the supported SFPs to your model:
Catalyst 3850 series | |||
Network Device | Transceiver Model | Minimum Software Release Required | |
DOM Support | Software Release | ||
| WS-C3850-12XS WS-C3850-16XS WS-C3850-24XS WS-C3850-32XS (with C3850-NM-8-10G NM) | GLC-T (10/100/1000) GLC-LH-SM GLC-LH-SMD GLC-SX-MM GLC-SX-MMD GLC-EX-SMD1 GLC-ZX-SM GLC-ZX-SMD GLC-BX-D GLC-BX-U CWDM SFP SFP-GE-S SFP-GE-L SFP-GE-T SFP-GE-Z DWDM SFP DWDM SFP (add.) GLC-BX40-D-I GLC-BX40-DA-I GLC-BX40-U-I GLC-BX80-D-I GLC-BX80-U-I | XE 3.7.1E, 16.1.1 | XE 3.7.1E, 16.1.1 |
| GLC-TE | – | XE 3.7.5E | |
| WS-C3850-12XS WS-C3850-16XS WS-C3850-24XS WS-C3850-32XS (with C3850-NM-8-10G NM) | GLC-TE | – | 16.5.1a, 16.3.5 |
| WS-C3850-48XS-S WS-C3850-48XS-E WS-C3850-48XS-F-S WS-C3850-48XS-F-E WS-C3850-48XS | GLC-T (10/100/1000) GLC-LH-SM GLC-LH-SMD GLC-SX-MM GLC-SX-MMD GLC-EX-SMD1 GLC-ZX-SM GLC-ZX-SMD GLC-BX-D GLC-BX-U CWDM SFP SFP-GE-S SFP-GE-L SFP-GE-T SFP-GE-Z DWDM SFP DWDM SFP (add.) GLC-BX40-D-I GLC-BX40-DA-I GLC-BX40-U-I GLC-BX80-D-I GLC-BX80-U-I | XE 3.7.2E, 16.2.1 | XE 3.7.2E, 16.2.1 |
| GLC-TE | – | XE 3.7.5E, 16.5.1a, 16.3.5 |
Please don't forget to rate all helpful responses and mark solutions!
Bst Rgds,
Andrew Khalil
01-30-2019 11:41 AM
Yes, it is correct!
Bst Rgds,
Andrew Khalil
01-30-2019 09:28 PM
