Problems with XFP10GLR-192SR-L
james.king14
Having problem with XFP10GLR-192SR-L module, trying to connect 10G link using ASR1004 with this module.  It will only see SONET it will not go to LR?
The module tests good with SONET but does not acquire a signal when using the 10G ethernet link.  Have had a BER test on link which was good.  Have changed several SFP's but need information whether this module can be changed?
Output of transceiver:
#show hw-module subslot 0/0 transceiver 0 status
The Transceiver in slot 0 subslot 0 port 0 is enabled.
  Module temperature                        = 23.503 C
  Transceiver Tx bias current               = 25120 uAmps
  Transceiver Tx power                      = -2.9 dBm
  Transceiver Rx optical power              = -3.4 dBm
  Module temperature                        = 23.429 C
  Transceiver Tx bias current               = 25128 uAmps
  Transceiver Rx optical power              = -40.0 dBm
  Module temperature                        = 23.488 C
  Transceiver Tx bias current               = 25106 uAmps
#show hw-module subslot 0/0 transceiver 0 ?
  idprom  transceiver idprom
  status  transceiver initialization status
#show hw-module subslot 0/0 transceiver 0 idprom detail
IDPROM for transceiver TenGigabitEthernet0/0/0:
  Description                               = XFP optics (type 6)
  Transceiver Type:                         = OC192 + 10GBASE-L (173)
  Product Identifier (PID)                  = XFP10GLR-192SR-L
  Vendor Revision                           = A
  Serial Number (SN)                        = SPC1639094K
  Vendor Name                               = CISCO-SUMITOMO
  Vendor OUI (IEEE company ID)              = 00.00.5F (95)
  CLEI code                                 = IP9IAGFCAA
  Cisco part number                         = 10-2542-01
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 12/09/20
  Connector type                            = LC.
  Encoding                                  = 64B/66B
                                              SONET Scrambled
                                              NRZ
  Minimum bit rate                          = 9900 Mbits/s
  Maximum bit rate                          = 11100 Mbits/s
  Power dissipation class                   = Pwr Level 1 (1.5 W max pwr dissipation).
  cdr function                              = supported.
  Tx Reference clock                        = not Required.
  Max link length for SMF fiber             = 10 km
  Max link length for EBW 50/125um fiber    = not supported
  Max link length for 0/125um fiber         = not supported
  Max link length for 62.5/125um fiber      = not supported
  Max link length for copper                = not supported
  Tx device technology                      = 1550 nm DFB
  Wavelength control technology             = no wavelength control
  Transceiver cooling technology             = un-cooled transmitter device
  Detector type                             = PIN detector
  Transmitter tuning                        = transmitter not tunable
  Supported CDR rates                       = 9.95 Gb/s
                                              10.3 Gb/s
                                              10.5 Gb/s
                                              10.7 Gb/s
                                              11.1 Gb/s
  Nominal laser wavelength                  = 1310 nm
  Wavelength tolerance w.r.t. nominal       = (+/-) 20 nm
  Maximum case temperature                  = 70 degrees C.
  Maximum power dissipation                 = 1500 mW
  Power dissipation in power-down mode      = 1500 mW
  Maximum current required for +5V supply   = 0 mA
  Maximum current required for +3.3V supply = 500 mA
  Maximum current required for +1.8V supply = 0 mA
  Maximum current required for -5.2V supply = 0 mA
  Diagnostic capabilities                   = FEC BER not supported.
                                              average Rx power measured.
  Enhanced functions                        = Soft TX disable supported
                                              Soft Power-down supported
  Aux A/D input 1                           = +3.3V Supply Voltage
  Aux A/D input 2                           = not implemented
  Transceiver temperature operating range   = -5 C to 75 C (commercial)
  High temperature alarm threshold          = +80.000 C
  High temperature warning threshold        = +75.000 C
  Low temperature warning threshold         =  -10.000 C
  Low temperature alarm threshold           =  -15.000 C
  High laser bias current alarm threshold   = 100.000 mAmps
  High laser bias current warning threshold = 80.000 mAmps
  Low laser bias current warning threshold  = 0.000 mAmps
  Low laser bias current alarm threshold    = 0.000 mAmps
  High transmit power alarm threshold       =  3.5 dBm
  High transmit power warning threshold     =  0.5 dBm
  Low transmit power warning threshold      = -8.2 dBm
  Low transmit power alarm threshold        = -11.2 dBm
  High receive power alarm threshold        =  3.5 dBm
  High receive power warning threshold      =  0.5 dBm
  Low receive power warning threshold       = -14.4 dBm
  Low receive power alarm threshold         = -17.4 dBm
james.king14
I may not have made myself clear..long day!  So is there a way to change the encoding of the transceiver?  Again the router is an ASR1004/SP10 trying to connect a 10G link.  It this module does not work can you recommend the correct one.
james.king14
Daniel Shriver
I am having the same difficulty. Was there a resolution to your question or did you find a solution?
V/R
Dan
