Problems with Zscaler ZPA and Cisco Umbrella Secure Client with SIG
we have the following Setup:
Device with Cisco Secure Client and SIG feature installed and all Traffic is routed via Umbrella + we are using Zscaler Client App with ZPA Config to have an tunnel to one of our clients for an specific application.
So in the past it was possible to use Cisco Umbrella and Zscaler if we exclude some Domains in Umbrella Portal for Zscaler:
gateway.zscloud.net
pac.zscaler.net
pac.zdxcloud.net
mobile.zscloud.net
prod.zpath.net
private.zscaler.com
smres.zdxloud.net
But after an Update for Zscaler to the Version: 4.3.0.181 we have Problems with Zscaler. A Login in Zscaler Client Connector is possible but after some seconds the Zscaler Tunnel is disconnected. If we Uninstall the Umbrella Secure Client or Disable the Cisco Umbrella Service then Zscaler is running. We excluded many other Zscaler Domains but without success. Do you have an idea?
Cionew
Problems can arise when Zscaler Private Access (ZPA) and Cisco Umbrella Secure Internet Gateway (SIG) are both running on a device. This can occur due to conflicting routing and DNS resolution, particularly when both services are configured to be fully tunnelled. Specifically, ZPA uses ZPA, which acts as a DNS proxy, conflicting with Cisco Umbrella's DNS encryption proxy software.
Marion County Property Appraiser
