VPN connect using Java
ReedBellamy70042
Community Member
Is there a way to connect and disconnect VPN in Forticlient programmatically? I see that with Cisco VPN Client, there are options such as using the APIs they provide or executing connectivity ...
Merritt
Community Member
Greetings,
I'm not certain how to do it programmatically with Cisco. But you may check this solution how to handle the disconnect, where a user wrote an expect script around the client: euer.krebsco.de
Paul Merritt, dissertation writer
https://dissertationwriter.org/
Jennings
Frequent Visitor
Frequent Visitor
Pretty much if you are working on building an Android VPN app, OpenVPN comes out as an option. Since OpenVPN has a lot of community support, you can easily build a VPN client for any platform. So I have created to an app in Java, using Android Studio.
Drum69
Visitor
@ReedBellamy70042 wrote: WestPennPower
If you want to connect to a server behind a private VPN, from the outside, nothing you can do on you app can/will allow you to do connect. Unless you launch a VPN client and programmatically connect your network, to that VPN server, your java app will just sit there waiting for a socket on http connect.
Jennings
Frequent Visitor
Frequent Visitor
A VPN client can be built using OpenVPN on any platform, since it is very community-based. Therefore, I have applied Android Studio to the Java app.
