Webex Card with Choices
nathy1984
Beginner
Beginner
I try to create a Webex Card with choices
My attachment:
attachment = {
        "contentType": "application/vnd.microsoft.card.adaptive",
        "content": {
            "type": "AdaptiveCard",
            "body": [
                    "type": "TextBlock",
                    "text": "My Choices Card"
                    "type": "Input.ChoiceSet",
                    "placeholder": "Placeholder text",
                    "choices": [
                            "title": "Choice 1",
                            "value": "Choice 1"
                            "title": "Choice 2",
                            "value": "Choice 2"
                    "style": "expanded"
            "actions": [{
                "type": "Action.Submit",
                "title": "Submit"
            "$schema": "http://adaptivecards.io/schemas/adaptive-card.json",
            "version": "1.2"
Unfortunately no card will be show.
If I remove this part of the code, I can see a card with a text "My Choices Card" and a Button.
                    "choices": [
                            "value": "Choice 1"
                            "value": "Choice 2"
                    "style": "expanded"
What is wrong with my attachment?
Best regards,
mneiding
Your input choice field is missing a id attribute. This should work:
            "body": [
                    "id": "test_id", # <- This is where you are missing the id
                    "choices": [
                            "value": "Choice 1"
                            "value": "Choice 2"
                    "style": "expanded"
            "actions": [{
                "title": "Submit"
            "version": "1.2"
mneiding
            "body": [
                    "choices": [
                            "value": "Choice 1"
                            "value": "Choice 2"
                    "style": "expanded"
            "actions": [{
                "title": "Submit"
            "version": "1.2"
Recognize Your Peers
