CiscoUCS API: NonRepeatableRead With HttpClient
jonathancantu
Community Member
I'm working on a Java service to periodically collect some metrics from the CiscoUCS REST API using the Apache HttpClient.  Even though I have a retryHandler, I seem to be hitting what's called a NonRepeatableRequestException:
Caused by: org.apache.http.client.ClientProtocolException
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:822)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:754)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:732)
at com.nimsoft.probe.application.cisco_ucs.sdk.CiscoUcsApi.getXmlResponse(CiscoUcsApi.java:585)
... 17 more
Caused by: org.apache.http.client.NonRepeatableRequestException: Cannot retry request with a non-repeatable request entity.  The cause lists the reason the original request failed.
at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:619)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:464)
at org.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:820)
... 20 more
Caused by: org.apache.http.NoHttpResponseException: The target server failed to respond
at org.apache.http.impl.conn.DefaultResponseParser.parseHead(DefaultResponseParser.java:101)
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:252)
at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:281)
at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:247)
at org.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:219)
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:298)
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125)
at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:645)
... 22 more
Is someone familiar with this?  Is there a way to gracefully handle or prevent this scenario?
Jonathan
0 Replies 0
