how to configure 1941 router Ethernet port with serial configuration
patwal019
I want to know that how do i configure my Giga-Ethernet port of 1941 series router for the same working as serial port.
actually my circuits are terminating over OFC and i want to change my old router with new one, i want that OFC output will terminate into my Giga-Ethernet port and work as same as that its working over serial port.
Mark Malone
You cant configure a serial port same as a Ethernet port there 2 different types of medium ,most of the commands wont take but the usual ones will like ip,  bandwidth etc will
what exactly is the configuration your trying to move from the serial to the Ethernet ?
