Hyperflex_Installer_Deploy_ Configuring Storage Node Error
pinjar84062
Dear All,
We are facing error with Cisco Hypeflex Installer during Deploy stage. We are trying redeployment on our Hyperflex. Below error is showing:
failed in Task: 'Configuring Network for Storage Controller VM' with Error: 'Configure networking script generated an exception: Failed to login controller VM(vim.fault.InvalidGuestLogin) { dynamicType = <unset>, dynamicProperty = (vmodl.DynamicProperty) [], msg = 'Failed to authenticate with the guest operating system using the supplied credentials.', faultCause = <unset>, faultMessage = (vmodl.LocalizableMessage) [] }'
Hyperflex Info is below:
UCS Manager IOS: 4.0(1C)
Hyperflex Installer IOS: 3.5.2f
We have also  attached error image.
We have no TAC support at that device. Please suggest me, how can resolve this problem.
try to use the Cisco default password of Cisco123 as the password when you run the installer
