Best approach for static route destination
hakenkreuz
|   CISCO2901      +------>+    MicroTik   +--> X.X.X.254
+---------------+                 X.X.X.253
     X.X.X.1
I have a CPE conected to a Service provider through a router MicroTik. I have IP X.X.X.1, management IP of MicroTik is X.X.X.253. When I do a show ip arp, there is a 3rd IP X.X.X.254 with a mac-address of a cisco device.
Ping to X.X.X.253 is 1 ms
Ping to X.X.X.254 is 12 ms
Traceroute to HQ always takes X.X.X.254, so this is our Gateway.
Question: What is the beeter approach to configure the default route?
a) ip route 0.0.0.0 0.0.0.0 X.X.X.253
b) ip route 0.0.0.0 0.0.0.0 X.X.X.254
c) It doesn´t matter
I have configured both and there is a slightly difference when trying to reach HQs IP
Eric101
Are all three devices in the same subnet?
Is there a policy (e.g. traffic shaping, firewall, etc...) being applied by the Mikrotik router?
If they are all in the same subnet and there is no administrative reason why your 2901s traffic should touch the Mikrotik router then your default route should likely point to .254
If I am understanding the post correctly a trace route shows x.x.x.254 as the first hop. In that case I agree that the next hop in your default route should be x.x.x.254. It is possible that both would work. But I believe that you would be better using 254 since it appears to be closer to your router.
Rick
Rick
