Cisco3620 Dial NMS problem
kurlas
i have one Cisco3620 router with one 8 ISDN Basic Rate interface, and version 12.2(6) IOS. The router is properly configured for ISDN dial-in users, and i want to monitor the active calls with MRTG, or RRDTools via SNMP queries.
I red about interested CISCO-POP-MGMP-MIB entries from Cisco's Dial NMS implementation guide, and when try to use these, the answer is:
$snmpwalk 10.1.0.1 drvread .1.3.6.1.4.1.9.10.19
enterprises.9.10.19.1.1.2.0 = Gauge32: 0
enterprises.9.10.19.1.1.3.0 = Gauge32: 0
enterprises.9.10.19.1.1.4.0 = Gauge32: 0
enterprises.9.10.19.1.1.5.0 = Gauge32: 0
enterprises.9.10.19.1.1.6.0 = Gauge32: 0
enterprises.9.10.19.1.1.7.0 = Gauge32: 0
enterprises.9.10.19.1.1.8.0 = Counter32: 0
enterprises.9.10.19.1.1.10.0 = Gauge32: 0
enterprises.9.10.19.1.1.11.0 = Gauge32: 0
enterprises.9.10.19.1.1.12.0 = Gauge32: 0
enterprises.9.10.19.1.2.1.0 = Counter32: 0
enterprises.9.10.19.1.2.2.0 = Counter32: 0
enterprises.9.10.19.1.2.3.0 = Counter32: 0
enterprises.9.10.19.1.2.4.0 = Counter32: 0
enterprises.9.10.19.1.2.5.0 = Counter32: 0
enterprises.9.10.19.1.2.6.0 = Counter32: 0
enterprises.9.10.19.1.4.1.0 = 100
enterprises.9.10.19.1.4.2.0 = 15
enterprises.9.10.19.1.5.1.0 = 2
enterprises.9.10.19.1.6.1.0 = 2
Can I somehow monitor the active call's with SNMP from 3620, or this works only with 5xxx ASs? Why doesn't work the mentioned MIB?
Best regards,
Qrta
mljohnson
Level 4
Level 4
Yes, this should be supported by the 3620:
http://www.cisco.com/public/sw-center/netmgmt/cmtk/mibs.shtml
MRTG should not be a problem, either:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/dialsol/nmssol/mrtg.htm
You may want to try the Network Management group for more help.
Thanks, I'll try them!
Qrta
